My stocker build.
My stocker build.
This is a discussion on My stocker build. within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; 2004 KLX 110 Tag X5 Supermini bars KX65 pegs with crf250 Peg springs Custom Vented front plate ASV front brake lever Gold kx60 front wheel ...
Results 1 to 15 of 15
    randee832's Avatar
    Jan 2006
    Roanoke Alabama
    My stocker build.
    2004 KLX 110
    Heavy front springs
    Heavey rear spring
    Custom plus 2 added to stock swinger
    N-style seat cover
    wayfastwhitey's Avatar
    Jan 2008
    Long Beach
    Re: My stocker build.
    u get that stuff from k0by
    randee832's Avatar
    Jan 2006
    Roanoke Alabama
    Yea
    PHATDAN420's Avatar
    Jan 2008
    Fort McMurray Alberta
    Diggin the seat brooo...the best part of the bike..hahah
    randee832's Avatar
    Jan 2006
    Roanoke Alabama
    Thanks i actually have the shroud graphics that go with the seat but im just over the black plastics for now.
    Banned
    ROBINSONDB22's Avatar
    Feb 2007
    KILLumbus, oHELLo
    that extended swinger looks sketchy is it solid?
  7. #7
    SUZUKIRM12594's Avatar
    Jul 2008
    Glendale California
    Quote Originally Posted by ROBINSONDB22
    Looks like welded iron or steel...Should be if it was done corectly. Nice way to keep within a budget.
  8. #8
    Jul 2008
    Glendale California
    Where did you get the vented # plate from??? I know cycra makes vented but dont know where to get one that would fit a mini...
  9. #9
    randee832's Avatar
    Jan 2006
    Roanoke Alabama
    Yea its pretty solid who ever added it took their time.
    I used my stock one and cut it out after seeing how the one on my big bike was done.
  10. #10
    Jul 2008
    Glendale California
    Quote Originally Posted by randee832
    Now those are some crazy cool Ideas you got there. How did you get the cuts so perfect? Can you explain the process in doin so? I'd really appreciate it...Thanx
  11. #11
    randee832's Avatar
    Jan 2006
    Roanoke Alabama
    Hhaha alot of patience is how. I basically marked a rough line with a sharpy (take off with carb cleaner) and cut it out with a die grinder then started shaving it with a razor knife and used a round file for the sharp degree in the corners and used sand paper to get the rough burs off at the end. It took me about an hr to just shave it down.
  12. #12
    Jul 2008
    Glendale California
    Aiight cool. Thanx!!! I'll definately be tryin that once my number/backing wears out.
  13. #13
    randee832's Avatar
    Jan 2006
    Roanoke Alabama
    The screen is just the cheap plastic vent stuff at walmarts but it will do till i find the right metal wire mesh i want. But another tip i learned was get one side to where you want it to stop then messure that and make marks to shave too.
  14. #14
    koby686's Avatar
    Apr 2008
    California
    that swingarm is solid my friend building prerunner roll cages hes the one that made that one for me.
  15. #15
    randee832's Avatar
    Jan 2006
    Roanoke Alabama
    yea it looks really solid thats for sure.
