Mikuni VM26-8074 vs. VM26-606
This is a discussion on Mikuni VM26-8074 vs. VM26-606 within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Does anyone know what the difference is between these two carbs other than the choke mounting? Mikuni carburetors from ProCycle Mikuni Carbs You can find ...
Results 1 to 14 of 14
    KJ790's Avatar
    Jul 2008
    New Hartford, NY
    You can find the VM26-8074 on ebay brand new really cheap, is it worth buying?
    mtbracer's Avatar
    Mar 2005
    Playa Del Rey, CA
    Re: Mikuni VM26-8074 vs. VM26-606
    You want the 606 for the 110
    MotoHP 180 W/SuperHead, KX65 Forks, Oil cooler, SIK EXT long travel swing with Elka Shock, and lots of other stuff.
    KJ790's Avatar
    Jul 2008
    New Hartford, NY
    Why can't you use the 8074?
    rideredmx2's Avatar
    May 2007
    ATX
    Quote Originally Posted by KJ790
    This is what u want to get.....26mm MIKUNI VM Round slide VM26-606 carburetor
    Side choke knob carb. Set up for mini 4-stroke motors
    Supplied jetting: Main 190, Pilot 22.5, Needle 5E75, Needle Jet 332 O-0
    The 8074 is a 2 stroke carb
    KJ790's Avatar
    Jul 2008
    New Hartford, NY
    Quote Originally Posted by rideredmx2
    But there is no distinction between a two stroke carb or four stroke carb other than jetting. Why can't I run an 8074 on a four stroke with it jetted properly. You can buy the 8074 for about $30 brand new on ebay. For the price difference I can afford to change the jets to make it run right. I'm just wondering if there is any real reason why this would not work.
    is Alive and well !!!
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    Exactly
    2006 STIMILON Masters of Mini Stock Class Champion
    BUILDER of mighty mini motors
    making chop suey out of the competition!!!
  7. #7
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    Run the $30.00 VM 26 and then you will find out what the difference is...the Pit Bkes will not run correctly
    Ive also hear that the internals may also be slightly different ???
    all I know is Ive seen both set-up and the 606 version is the best
  8. #8
    KI6HNB's Avatar
    Jul 2007
    Shingle Springs, CA
    How do I find out what version I have? It came with my TB143 kit.
  9. #9
    Paxracing's Avatar
    Mar 2004
    ca
    You can make the 8074 work it uses diff. size jets then the 606. There is differences in the carb's the 8074 has a jet in the back of it that the 606 doesnt have. I got a carb from two brothers which was the 606 and had Mikuni fuel meter it compaired to the 8074 now Mikuni brings in the 606 it flowed and carborated easlier and better.
  10. #10
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Use the search...this topic has been covered before. I've had both and did direct swap outs of each carb on a 155cc motor. The difference was significant. Get the 606.
  11. #11
    Paxracing's Avatar
    Mar 2004
    ca
    Quote Originally Posted by KI6HNB
    TB sells the 606 carb.
  12. #12
    Pat Farsole's Avatar
    Nov 2006
    The VM26 - 606 is a smaller carb ... it has a VM24 slide whereas the VM26-8074 has a VM28 slide ... meaning the venturis must also be different sizes as well ... The main difference between a carb set up for a 4 stroke vs a 2 stroke is that the four stroke requires smaller jets and a perforated needle jet ...
    Sudco Mikuni VM Carburetors
    4Strokes.com - Tech: Carburetor Jetting - Magazine Reprint
    And as for "set up for a 4 stroke" ????? ... Check out a jet size chart to see what a Mikuni #190 main equals in Keihin main jet size ... Somethin's just not addin' up .....
    Width------Keihin # -- DynoJet # -- Mikuni #
    0.0350---- 92.5--------- 92---------- 86.3
    0.0360---- 95----------- 94---------- 88.1
    0.0370---- 97.5--------- 96---------- 90.0
    0.0380---- 100---------- 98---------- 91.9
    0.0390---- 102.5------- 100---------- 93.8
    0.0400---- 105--------- 102---------- 95.6
    0.0410---- 107.5------- 104---------- 97.5
    0.0420---- 110--------- 106---------- 99.4
    0.0430---- 112.5------- 108--------- 101.3
    0.0440---- 115--------- 110--------- 103.1
    0.0450---- 117.5------- 112--------- 105.0
    0.0460---- 120--------- 114--------- 106.9
    0.0470---- 122.5------- 116--------- 108.8
    0.0480---- 125--------- 118--------- 110.6
    0.0490---- 127.5------- 120--------- 112.5
    0.0500---- 130--------- 122--------- 114.4
    0.0510---- 132.5------- 124--------- 116.3
    0.0520---- 135--------- 126--------- 118.1
    0.0530---- 137.5------- 128--------- 120.0
    0.0540---- 140--------- 130--------- 121.9
    0.0550---- 142.5------- 132--------- 123.8
    0.0560---- 145--------- 134--------- 125.6
    0.0570---- 147.5------- 136--------- 127.5
    0.0580---- 150--------- 138--------- 129.4
    0.0590---- 152.5------- 140--------- 131.3
    0.0600---- 155--------- 142--------- 133.1
    0.0610---- 157.5------- 144--------- 135.0
    0.0620---- 160--------- 146--------- 136.9
    0.0630---- 162.5------- 148--------- 138.8
    0.0640---- 165--------- 150--------- 140.6
    0.0650---- 167.5------- 152--------- 142.5
    0.0660---- 170--------- 154--------- 144.4
    0.0670---- 172.5------- 156--------- 146.3
    0.0680---- 175--------- 158--------- 148.1
    0.0690---- 177.5------- 160--------- 150.0
    0.0700---- 180--------- 162--------- 151.9
    0.0710---- 182.5------- 164--------- 153.8
    0.0720---- 185--------- 166--------- 155.6
    0.0730---- 187.5------- 168--------- 157.5
    0.0740---- 190--------- 170--------- 159.4
    0.0750---- 192.5------- 172--------- 161.3
    0.0760---- 195--------- 174--------- 163.1
    0.0770---- 197.5------- 176--------- 165.0
    0.0780---- 200--------- 178--------- 166.9
    0.0790---- 202.5------- 180--------- 168.8
    0.0800---- 205--------- 182--------- 170.6
    0.0810---- 207.5------- 184--------- 172.5
    0.0820---- 210--------- 186--------- 174.4
    0.0830---- 212.5------- 188--------- 176.3
    0.0840---- 215--------- 190--------- 178.1
    0.0850---- 217.5------- 192--------- 180.0
    0.0860---- 220--------- 194--------- 181.9
    0.0870---- 222.5------- 196--------- 183.7
    0.0880---- 225--------- 198--------- 185.6
    0.0890---- 227.5------- 200--------- 187.5
  13. #13
    SUPERMOTARD29's Avatar
    Jun 2007
    houston tx
    this is the first time i see this question answer !!
    thank you!
  14. #14
    bkillar's Avatar
    Sep 2014
    Bump to the top
mikuni vm 26
mikuni vm 26 8074
mikuni vm26
mikuni vm26 606
mikuni vm26 8074
mikuni vm26 carburetor
mikuni vm26-606
mikuni vm26-8074
mikuni vm26ss carburetor
vm26 606
vm26-606
vm26-8074
