12" front wheel on klx110 - Page 2
This is a discussion on 12" front wheel on klx110 within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; How can you use rear spokes up front when the front spokes are 2 diff lengths ??...
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    JohnnyB's Avatar
    Nov 2003
    CT
    Re: 12" front wheel on klx110
    Just say'n .... Hidden Content
  2. #17
    w650gb500's Avatar
    Nov 2005
    Wilkes-Barre, PA
    It's been a little while and since my brain isn't what it used to be, I believe you. I did my last 110 with a set of BBR HD spokes and a KX-60 rear hoop. Do the KX-60 rear spokes work with the front hub? Maybe that's what I was trying to remember. Sorry for any mis-information.
    Dan
  3. #18
    flugie's Avatar
    Aug 2004
    cycles 128 beverly ma.
    actually you do need a kx 60 rr rim.the only problem is the hole angle in the rim is wrong so you need to redrill the holes a bit.kx 60 rr hub is a bit wider so spoke angle is greater.(just built one a few days ago.)1.5 hrs is quite fair to build one of these w/mods done.i build a lot of wheels too,.5 hr. is wat too light-honda flate rate by the book is 2.2 hrs for a front rim replacement(whole bike-wheel on) on a 2007 crf50
  4. #19
    JohnnyB's Avatar
    Nov 2003
    CT
    Quote Originally Posted by w650gb500
    Dan
    I was told by a couple of diff people that the only place to get 12" front spokes was from Buchanan ..
    I know the 110 rears are like 50 ones where all of the seem to be the same legth .
    Kx 60 spokes .., Idk what their lengths are .
  5. #20
    JohnnyB's Avatar
    Nov 2003
    CT
    Quote Originally Posted by flugie
    Wow .., flate rate is 2.2 for a 50 ???????...., Maybe I could make a tenth on the job .
  6. #21
    flugie's Avatar
    Aug 2004
    of course that is on /of the bike and tire installed.i was surprised but it does take time to get correct .i looked the time up on hondas dealer only website we use.how did you make out on your wheel build?
  7. #22
    Subaruzi's Avatar
    Jan 2016
    Did you figure out the spokes on this?
    Sent from my SM-G900V using Tapatalk
buchanan spokes klx110
excel rims
how to put excel rims
kawasaki ksr rim
klx 110 12 front wheel
klx110 wheels
ksr offroad
ksr rims
ksr tires
ksr wheels
rims for ksr
what size and diameter is a 2006 klx 110 pit bike
