Yx 160 Top End-60Mm Piston Will Make Your 110 A 143Cc
This is a discussion on Yx 160 Top End-60Mm Piston Will Make Your 110 A 143Cc within the KLX110/Midsize Parts for Sale forums, part of the Classifieds category; YX top end - $170 shipped -cylinder, piston, head, rear facing manifold, and 26mm carb -60mm piston will make a klx110 a 143cc -came off ...
Results 1 to 16 of 16
    is waiting for 928mx.com RACE
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    $170
    YX top end-$170 shipped
    -came off a SSR 160r, only 4 hours
    -OD of cylinder skirt is about 65.8mm so oem klx case would need to be bored
    thats a good thing because you can actaully bore this cylinder down the line and go bigger! and not just trash it or reuse an out of spec cylinder for the same size bore.
    -I'll split the kit up, just give me an honest offer
    -For 03 - UP
    2010 Up must use
    TB Cam Sprocket for KLX & DRZ110 2010 UP
    For TB Race Heads
    TB part#[TBW0645]
    mi420ke@aol.com for paypal
    I've got some more ssr160r crf70 parts in the below link:
    ssr crf70
Name:	029 - Copy.JPG
ID:	68643   Click image for larger version.
Name:	027 - Copy.JPG
ID:	68644   Click image for larger version.
Name:	028 - Copy.JPG
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    ttt
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    ttt
    is If you ain't first your last,
    I wanna go fast like Ricky
    bobby
    4thtapped's Avatar
    Jul 2011
    Western Ky
    So it's not a yx160 it's a yx143 right? I'm confused bc a 160 bore is way bigger then a 143
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    Quote Originally Posted by 4thtapped View Post
    Thanks for asking because most people don't know engine specs. Its from a yx160, the yx has a longer stroke than a klx110 which makes up the difference in cc's.
    klx110 - 50.6mm (oem crank) x 53mm (oem piston) = 111cc
    klx110 - 50.6mm x 60mm piston =143cc
    klx110 - 55mm (stroked crank) x 60mm piston= 155cc
    klx110 - 50.6mm x 64mm = 162cc
    klx110 - 55mm x 64mm = 177cc
    yx160 - 57mm crank x 60mm piston = 161cc
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    Below is a link for anyone trying to figure engine size/spec
    engine calculator
  7. #7
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    Quote Originally Posted by stickyicky View Post
    ssr crf70
    ^Probably less. Great condition
  8. #8
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    ttt
  9. #9
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    ttt
  10. #10
    bmw603's Avatar
    Jan 2010
    New Hampshire
    for the record you'll need to bore the cases to install it.
  11. #11
    mattman218's Avatar
    Oct 2010
    No he's right. Just put this same setup on a klx110 and had to bore the cases. If it was a true 143kit for a klx you wouldn't have to, but this way you do. Also the intake faces rearward so that wont work on a klx either. Don't want to see someone run into the same problems as I did without knowing it before hand. Not trying to bad mouth the kit your selling, just want to clear the air on boring the cases, you have to bore them!!
  12. #12
    bmw603's Avatar
    Jan 2010
    New Hampshire
    told ya, and thanks for "trying" to give accurate information
  13. #13
    is looking for forks and a pipe
    electricflo's Avatar
    Oct 2011
    Dickinson,Texas
    yes u do have to bore your cases i tried the same cylinder and didnt fit! BMW603 is completely correct !
  14. #14
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    ^Thanks for the info. Sounds stupid to me to bore your cases for just a 143cc kit unless you have plans to go bigger later. So that in mind I will sell just the parts separately that anybody wants.
  15. #15
    bmw603's Avatar
    Jan 2010
    New Hampshire
    Good luck with the sale. It's a good kit, just takes a bit more work. I have a TB 143 kit with stock head and my brother has the cylinder and head you're selling. Mine pulls better low end but he has a lot more top end power. So depends on how you ride really. It's a nice kit and I was impressed, but it is a lot of work.
  16. #16
    SERIES 5/12/12
    stickyicky's Avatar
    Jul 2006
    Bootleg Canyon, NV
    Quote Originally Posted by bmw603 View Post
    You brother obviously needs to tune his, since the yx race head has almost twice the size as stock valves, a race cam, and higher compression. So that statement should be completely false in real life. If it was tuned properly, it would be a torque monster down low. A stock head pull better. I'm LMAO.
    This kit is know for basically having major torque down low and then signing off on the top end like a typical mod 110 motor. <That's what you should expect or there's something wrong! It is basically a Trail bikes pre V2 kit.
Sponsors
klx 143 vs yx piston
klx trail bikes 143cc kit has bad bog
