Need advice for total Motard Newb
This is a discussion on Need advice for total Motard Newb within the Mini-Motards forums, part of the General Talk category; Originally Posted by aedwards07 Thanks alot guys.I guess I will go with the Sl26's.Also I have Cyclone rims not china junk.How much of a disadvantage ...
Page 2 of 2 FirstFirst 1 2
Results 21 to 37 of 37
  1. #21
    moosehunter's Avatar
    Aug 2005
    Cologne, Minnesota
    Quote Originally Posted by aedwards07
    Thanks alot guys.I guess I will go with the Sl26's.Also I have Cyclone rims not china junk.How much of a disadvantage is the 12inch front?I could possibly build one since I have all the parts, but its just a PITA to build them in my opinion.
    -Austin
    Good tire choice for the money. I ran those before the Dunlops. I really can't comment on the 12" front. However, on a tight track, I can see where it "may" slow down the steering too much. Only a guess...
    Moosehunter (aka: Dan)
    "When in doubt.... GAS IT!"
  2. #22
    filthyboatguy's Avatar
    Oct 2004
    San Diego, CA
    -Austin
    Try it, my Son hated the 12" front, but if you ride super aggressive you may be able to turn it fast and stick it better.
    2003 XR88R STUNT
    2005 CRF108R SM
    2006 KLX111R SM
    Thanks to Factory Motorsports, anyonebut_24, Minigunz, RJP Racing and M&M Racing for all the help!!
  3. #23
    taz69's Avatar
    Nov 2005
    Moosehunter & JohnyB I race SEMRA Down here in the south.... And Moosehunter My set up almost identical looks with stock plastic Identical but I have a takegawa 95cc for the 100 and under class we sweep it... I have those SP5 and i have there stiffer setup if U call BBR they wiil send U stiffer damping rods and springs along with the 30wt oil... It will allow U to REALLY slam the front and turn much shaper.... The 10 inch rims are the best and quickest for turning there only down fall is if the speeds get over 60 or so they become twitchy but that doent happen at the track only when ridding around town... we also have 4 speeds in the bikes and very low Moose handel bars...I also have just a 1 inch longer swing arm to keep the OVERALL length down as a longer bike goes from side to side a little slower and is harder to hold a TIGHT line around some of the 180 turns on a cart track..
  4. #24
    JohnnyB's Avatar
    Nov 2003
    CT
    Taz , BBR has an even more stiffer set up than the current upgrade to the SP5's ??
    Just say'n ....
  5. #25
    is just truckin' along...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Quote Originally Posted by filthyboatguy
    I just got a thing for the more minimalist lookin' bikes! Pure function!!
    I guess it's cause I can't afford all the bling-bling
    Doesn't get any more minimalistic than this...
    - dirtbkr188 -
  6. #26
    JohnnyB's Avatar
    Nov 2003
    CT
    Yea , that bike is so bare bones . You aren't even run'n grips ...
    Just say'n ....
  7. #27
    dirtbkr188's Avatar
    May 2004
    New Jersey
    too much wind resistance...
    - dirtbkr188 -
  8. #28
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Here's some OLDSCHOOL minimalism, for you purists...
    - dirtbkr188 -
  9. #29
    Kurlon's Avatar
    Feb 2005
    Southern Maine
    The 12" front shouldn't be a problem, it's what I run, and despite my 70 dwarfing all the 50s at Cycles 128, it wasn't having problems hitting the same lines as the 50s, unlike the YZFs that had one line, and one line only through the chicane.
  10. #30
    JohnnyB's Avatar
    Nov 2003
    CT
    Wind resistance ??? Those damn kill buttons stick up so high on both of your bikes , I bet your bikes turn left really easy from all that wind drag on them ...
    No grips again !!!
    Just say'n ....
  11. #31
    JohnnyB's Avatar
    Nov 2003
    CT
    Quote Originally Posted by Kurlon
    Oh yes it was !!!! Have a look below !!!
    Friends don't let friends post pics on forums .....
    Just say'n ....
  12. #32
    Oct 2004
    San Diego, CA
    Quote Originally Posted by JohnnyB
    Grip are so overrated.........Just knurl the bars like OC Choppers.
    2003 XR88R STUNT
    2005 CRF108R SM
    2006 KLX111R SM
  13. #33
    dirtbkr188's Avatar
    May 2004
    New Jersey
    ... I bet your bikes turn left really easy from all that wind drag on them ...
    Actually, the kill button is a highly sophisticated GPS/LASER/Gyroscopic directional facilitator that will automatically move upward into the airstream whenever a weight shift to the left is premeditated by the rider. The micro-mini hydraulic actuator assembly was drafted, designed, and prototyped by Kurlon, who still remains very tight-lipped about it, to this day. He'll deny knowing anything about, just ask him. I believe he is developing something for the throttle housing side, and it involves a NASA nose cone tile piece.
    - dirtbkr188 -
  14. #34
    JohnnyB's Avatar
    Nov 2003
    CT
    Quote Originally Posted by dirtbkr188
    Yea , it looks as if he's deff got alot of fine tune'n to do with that throttle gizmo cause it seems to add too much lean angle on that side .
    Just say'n ....
  15. #35
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    Austin, if you have the parts I will build a 10" front for you..(I'll build it for Free you pay shipping both ways) I haven't tried a 12" up front I know the 10" up front works real well
    Mini Me Racing #38
    FLY Racing Gear
    Torco Oils
    Oldschool Built
    Moto Nutrition
    Customized Creationz
    Mini Me Racing: " We Make Chop Suey Out Of The Competition"
    2006 Transworld Motocross Masters of Mini Stock Class Champion
  16. #36
    TRT
    TRT is offline
    TRT's Avatar
    Nov 2005
    Earth
    The key is to slow down with the front brakes before you turn!
    And yes the 12" rims suck for tight go kart(sized) tracks.
    One fine day!
  17. #37
    sanoman23's Avatar
    Dec 2004
    Here are some pics of my motard:
    http://putfile.com/pic.php?pic=10/30114072855.jpg&s=x11
    http://putfile.com/pic.php?pic=10/3011408169.jpg&s=x11
    If you have any questions feel free to ask!
    Sanoman23
