KTM 65 brake alternative
This is a discussion on KTM 65 brake alternative within the Mini-Motards forums, part of the General Talk category; what other brake caliper will bolt to a KTM 65 from end with out any mods?...
Results 1 to 10 of 10
    feanaro1313's Avatar
    Apr 2015
    Garret's Avatar
    Mar 2014
    None that I am aware off. All need some form of adapter, however there are some that you can buy. Ktm65 needs a bigger rotor once you motard it anyways unless you are under 100lbs of race weight
    1975 CT70 - YX160, extended swinger, shocks, inverted forks, 12inch rims with 120 front 130 rear, Disc Brakes
    07 Motorvert Pro frame - YX200, Custom Exhaust, 255mm Front Disc with Radial Caliper, Marzocchi Forks, Elka Rear Shock, 12 inch PMT Slicks
    Backup B Bike - 110cc, 10 inch PMT Slicks
    mactech's Avatar
    Jan 2007
    SPAIN
    NG Brake Ref.1379XK22
    or
    Oversized Front Brake Rotor Kit KTM 65
    is New bike!!! New build!!!!
    Domangue418's Avatar
    Oct 2013
    Youngsville, LA
    That kit only fits 09-newer. Will not fit older versions!!!!! I called them a couple weeks ago
    WALKING EAGLE (too fat to fly)
    mactech's Avatar
    Jan 2007
    SPAIN
    Quote Originally Posted by Domangue418 View Post
    for the brake caliper ???
    Oct 2013
    Youngsville, LA
    Yes sir. That's what I was told
    mactech's Avatar
    Jan 2007
    SPAIN
    Strange???? according to ngbrakesdisc:
    Referencia: 1379XK22
    SIDE:
    OUTSIDE: *225
    INSIDE: 89
    THICKNESS: 3,0
    Nº HOLES: 3
    HOLES: 6,5
    KTM - 65 - SX - 2000/2016 - 1-MOTO - FRONT - L -
    mactech's Avatar
    Jan 2007
    SPAIN
    another option is only to use the disk and use a better caliper.
  10. #9
    Blighty's Avatar
    Feb 2014
    [QUOTE=mactech;2107945]for the brake caliper ???
    The rotor fits, but the relocation bracket fouls the forks - you have to fabricate an alternative relocator. I have one on a'05 sx65.
  11. #10
    BuckIt's Avatar
    Jan 2012
    N.E OHIO
    All the options posted so far are 2x-3x the price of used OEM Ktm brakes.
    They are top tier parts, but come with a top tier price.
    "Rooining it"
  1. BBR brake pedal alternative options
    By truckguy in forum KLX110, DRZ110, TTR90
    Last Post: 06-10-2014, 02:07 PM
  2. Replies: 6
    Last Post: 07-20-2011, 12:46 PM
  3. ktm 65 front brake
    By TNTminis867 in forum Bikes and Parts Wanted - All Makes
    Last Post: 05-25-2010, 08:00 AM
  4. ktm front brake
    By 507 brett in forum KLX110, DRZ110, TTR90
    Last Post: 06-15-2008, 07:48 PM
65sx brake pedal
