What is the best rear shock for a KLX Motard
This is a discussion on What is the best rear shock for a KLX Motard within the Mini-Motards forums, part of the General Talk category; Finishing up my KLX build and am left with the back end to upgrade. I am planning on doing a BBR Super Stock Swingarm and ...
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By jason04r1
Thread: What is the best rear shock for a KLX Motard
    Kirchnerbrn's Avatar
    Jul 2016
    Hastings, MN
    Finishing up my KLX build and am left with the back end to upgrade. I am planning on doing a BBR Super Stock Swingarm and K&J Rear rim with Mitas Tires but am still on the fence with the rear shock. I grew up riding Mountain bike and I know the Fox Float is one of the most adjustable shocks out there. But how does it do on the street. Is Elka the way to go? All the local guys keep telling me to just come out and ride but I want to get this right so I can enjoy it. What other shocks do you recommend. I have Marzocchi forks so I need something taller to balance out the bike.
    Jul 2016
    Hastings, MN
    Oh and I forgot, I like beer so i'm 200 pounds....
    Yummm.....Beer.
    jason04r1's Avatar
    Dec 2015
    Elka is a great choice. I used ÷hlins on my fiddy and it was an incredible shock. My street legal Perimeter uses an ÷hlins from a Grom and its great. DNM is also a great choice if youre on a budget.
    Wrench's Avatar
    Mar 2010
    West Richland, WA
    The Elka works fantastic for me on the X4. Not sure if the frame geometry is similar or not, but the stock X4 frame geometry left the Elka feeling soft until I relocated the upper shock mount. Running a motard hard requires a rear setup that doesn't settle so deep in the corners making the pegs drag hard.
    is living the american dream!
    KlxRacer#2's Avatar
    May 2010
    we scrub harder in Ohio!
    Quote Originally Posted by jason04r1 View Post
    bbr perimeter ? have pic of the setup ?
    2010 BBR 50
    2011 BBR v3
    2004 Honda Cr125
    2015 Piranha 190
    2015 Gorilla 190
    2015 Trail 70
    Thanks to Wholesale-Cycle, TB Parts and BBR Motorsports
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    the DNM shock for the klx110L is the best shock I have used so far for road racing, the fox float is nice but too short, however you can buy the 1" spacer. I have had 2 I-shocks one of them being there top of the line and both sucked, works sucked too especially since there is no way to adjust it. Never tried the elka or olhlins so cant speak on those but if there is no adjustment knobs on them and 275mm long then I wouldn't bother with them. Now if ohlins offered a 275mm fully adjustable shock like the one I have on my grom I would run it
    TMGP #78
    TEAM I JUST WANNA RIDE #104
    Come Out & Join Us Hidden Content
    jason04r1's Avatar
    Dec 2015
    I have an ÷hlins shock from a Grom on my perimeter. I believe its a china frame but its dead nuts the same as my other bike. Im also using a 190R swingarm
    Attached Thumbnails Attached Thumbnails Click image for larger version.†
Views:	36†
ID:	187234Click image for larger version.†
Views:	25†
ID:	187242Click image for larger version.†
Views:	28†
    rob78 likes this.
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    looks good on there but its only 250mm which is shorter than a stock klx shock. you want the longest shock you can fit on the to give you more round clearance and that 275mm
    also with the piggy back reservoir it wont fit a klx
    TMGP #78
  10. #9
    jason04r1's Avatar
    Dec 2015
    True and true. However 275 wont fit this bike bc of the swingarm shock mount is too tall. I modified the frame to allow the external reservoir. Shock is incredible. May be steppig up to more spring bc of the longer swingarm.
  11. #10
    Jul 2016
    Hastings, MN
    I am looking at running a Ebay SSR extended swingarm that will be 17" which stock is 14.5" which is a +2.5. All I will need to do is grind down the Bosses on the frame 2.5mm each side to make it fit. Then to decide what shock to run. I am thinking the DNM Shock is the way to go but the longest one is a 275 On T-Bolt. I am thinking I will order the swingarm and Measure up a couple rods to find the correct height. My only concern is I don't want to mess with the Geometry of the rear end too much with a overly long shock.
  12. #11
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    I don't think the klx110 DNM shock will work with the ssr swingarm
    TMGP #78
  13. #12
    GLMMRS's Avatar
    Feb 2006
    Michigan
    Quote Originally Posted by rob78 View Post
    Hey Rob - so what is the ideal length of a KLX for roadracing? Stock frame, BBR stock-mod style swingarm. I'm in the process of building one now. KTM 65 front forks and an Elka shock that's 270mm. Elka asked for an eye to eye length and I sort of guessed.
    I have seen a shock length extender, but it goes up 30mm roughly and that's it. Basically just an eyelet "extension".
    Thanks.
  1. KLX Rear Shock.....HELP!
    By Willydog in forum KLX110, DRZ110, TTR90
    Last Post: 08-23-2014, 06:43 PM
  2. best rear shock for motard
    By podium123 in forum Mini-Motards
    Last Post: 08-16-2010, 06:39 AM
  3. Klx 110 hd rear shock
    By kawasaki304 in forum Feelers and What is my bike/parts worth?
    Last Post: 03-15-2010, 07:28 PM
  4. KLX110 motard road racer what rear shock to use?
    By Bagwell in forum Mini-Motards
    Last Post: 01-31-2009, 06:41 PM
  5. KLX 110 Mini motard rear suspension set up !!
    By ishc in forum KLX110, DRZ110, TTR90
    Last Post: 09-15-2006, 11:59 PM
Ľ Log in
Ľ Sponsored Links
