FAQ's about Mini SuperMoto
This is a discussion on FAQ's about Mini SuperMoto within the Mini-Motards forums, part of the General Talk category; Hey Moderators, can you make this a sticky. Then maybe allow a few additions to my posts. Then lock it. This is an information post. ...
Results 1 to 15 of 15
    Cam @ M&M Racing's Avatar
    Feb 2006
    Westminster, SC
    Hey Moderators, can you make this a sticky. Then maybe allow a few additions to my posts. Then lock it. This is an information post. Not a place to ask questions. Thanks, Cam
    FAQ’s about Mini Super Moto;
    1. Do I need 12” rims front and rear? A: Not required but 14” tires are very hard to find.
    2. Do I have to change my 10” rims on my 50? A: No, use an 80/90-10” or a 90/90-10” tire.
    3. If I have a 12” front and 10” rear, do I have to build 2 matching rims? A: Not required but not the ideal set up. It would benefit you to have matching rims.
    4. Can I mount a 120/80-12” tire on a 1.60” x 12” rim? A: Yes but it is not a good selection. Use a 90/90-12” or a 100/90-12” tire.
    5. Will a 3.50” x 10” tire fit between the stock forks on a CRF/XR 50? A: No.
    6. Will a 120/80-12” tire fit in the swing arm of my KLX110? A: Yes. Unless you have a 15hp engine or more, you do not need a 120/80-12” rear. Use a 100/90-12” front and rear.
    7. Can I use a 2.50” x 12” rim on the rear of my Mini? A: Most mini’s will accept a rear 2.50” but it is personal preference.
    8. What is a slick versus a DOT? A: A slick is not legal for the street. A DOT has small grooves and are street legal.
    9. Are heavy duty spokes and nipples required? A: No, but the stainless steel nipples and spokes are much stronger.
    10. Where do I get Mini Super Moto parts? A: Do a “Google” search. Type in “mini road racing”.
    11. Why won’t my tire seat? A: You need a heavy duty tube. You need a small amount of soap. Surgical soap seems to work best. You may need up to 100 psi. Be careful!!!!!
    12.
    teddy's Avatar
    Oct 2005
    southeast MI.
    Re: FAQ's about Mini SuperMoto
    I'd agree on most of this. Plus 2 cents
    A 3.50" X 10" BT39 fits on my 2005 CRF50 stock rim/fork, I did have to trim the rubber dust seals for this to work..... The HD forks springs with +1" fork legs are a bonus on the CRF50, and a high rise bar set-up.
    Other lubricant alternatives to seating the rim are spray vegetable oils (canola, corn, sunflower etc..) these work really well and are not going to degrade the natural rubber oils from the tire.
    Rims seem to play a part in the seating of the bead....... a proper width rim will help you out (wider vs narrower rim). A quality rim helps too.
    The Fox air shox has been the best unit for the older A style swingarms for the CRF50 clone bikes for Road racing and "motarding" on pavement/dirt tracks.
    Quality oil with frequent changes have proven to make motors/gear boxes last and perform at peak HP.
    The fastest tires most racers have used in 10" and 12" for road racing are:
    12";
    TT91 now TT92.
    BT601, currently unavailable in the US.
    Sava MC31
    Some like the Michilin Pilot sport.
    10";
    TT91/92 Dunlop
    BT39 Bridgestone
    MC0 Sava
    For pavement/dirt any of these with extra grooves cut into them hook up decent in the dirt sections. The SAVA 10" rains work great in this application.
    16" tires and 17" tires anyone? There are people using various 17" slicks on some of the bigger sized bikes, I believe most are running the Dunlop or Bridgestone soft slicks. I'm unsure of the sizes commonly used.........
    Bar end sliders vs 'Bark Busters' = personal choice. Pros and cons to both styles of protection.
    Bar height = personal prefference. Some people like lower bars vs higher bars. Motard vs Road racing is part of the equation. The size of the bike falls into this equation as well. The riders physical size as well. If you like a fully crouched GP125 position you might like clip-ons or flat bars, even clubman bars. If your a flat tracker you might like wider flatter styled bars. If your into the upright position on a "pitbike" you might like the taller "pitbike" bars.
    apexmfg.com
    sportbiketracktime.com
    mimra.org
    Kurlon's Avatar
    Feb 2005
    Southern Maine
    Stickied, still open for posts.
    JohnnyB's Avatar
    Nov 2003
    CT
    Quote Originally Posted by Kurlon
    Truth be told ????
    For me ..., it's the closets your gonna get to big bike road race'n with out the crazy costs .
    The crash damage costs are are minimal , that is ..., unless your Kurlon ...
    He always seem to push the envelope in this dept. ....
    How's the say'n go ???
    If your gonna F up ..., F up big ...
    Just say'n .... Hidden Content
    Kurlon's Avatar
    Feb 2005
    Southern Maine
    Wow, I've been drive by slammed in a sticky'd FAQ thread... when are you going to be at NHMS or 106 Race Park again so I can return the favor?
    JohnnyB's Avatar
    Nov 2003
    CT
    Well .., I'm glad to see your 100% again !!!!
    Hopefully you'll get your chance before too long ..
    Money is real tight for me now since I'm try'n to put together a 110 for Rt 106 .
    lilskully's Avatar
    Aug 2008
    Charleston, SC
    2 Questions.
    1.) I am looking to bump-up from 10" front and rear, to 12" front and rear. I have seen both 12x1.60 and 12x1.85. Which is better? I will be running the Sava tires on them, if that helps determine the outcome.
    2.) Steel or aluminum rim. I will only run on paved tracks. No offroad or jumps.
    Thanks in advance.
    Dan da man
    P.S. Cam. We met about a month ago in Elgin. I was the only adult riding a stock 50 that day. It was the one with the red/black skull graphics. You have seen my riding style, and how hard I push that lil thing. Please advise soon! Thanks.
    Feb 2006
    Westminster, SC
    I repeat, this is not a place to ask questions. Kurlon, please delete every post after #2. This is for info to cut out all the same questions that people are still asking any way. I tried to help out and people are still asking the same questions any way.......... Cam
    Lilskully, run 2.15" front and rear with the Sava's. If you have Marz, 1.85" front.....
  10. #9
    kman153's Avatar
    Aug 2008
    boston
    are the 12 front and 12inch rear better handling for motard than a 14 inch front and 12 inch rear?
  11. #10
    MAZZ77X's Avatar
    Oct 2006
    Right down the road from NJMP
    A 50/50 solution of simple green makes getting tires to seat a breeze. Also works great for mounting and then cleaning to remove all residue.
    60-70 psi still needed though.
    2006 Pitster X2 Team T-BOLT USA 2007 Team Member
  12. #11
    is Moderator in training?
    s_10onbagz's Avatar
    Sep 2007
    Connecticut.
    I never noticed this thread. Windex works well for mounting tires, but dries pretty quick. Also remember a wider rim does more than a wider tire. I wish somebody would post more info on finding races. I have a bike to race with only one race a year. :/
  13. #12
    teddy's Avatar
    Oct 2005
    southeast MI.
    DUDE....................... you must be kidding.............
    NJ MiniGP • Racing has never been so much fun!
    Come on man thats soooooooooooooooo close and off the hook
    apexmfg.com
    mimra.org
  14. #13
    s_10onbagz's Avatar
    Sep 2007
    Connecticut.
    I wish they listed bike and gear requirements.
  15. #14
    JohnnyB's Avatar
    Nov 2003
    CT
    Quote Originally Posted by s_10onbagz
    Idk .., I found it pretty easy on there site ..
  16. #15
    TTR50E's Avatar
    Oct 2009
    Aliso Viejo, CA
    Where can I get a wider 10" rim than 1.60???
12 inch rear 14 inch front pit bike wheels pros and cons
12 supermoto tires
best mini supermoto
mini motard 12 ince tyre
mini super moto
mini supermoto
mini supermoto forum
mini supermoto parts
minisupermoto
supermoto
supermoto mini
supermoto mini parts
