Widest tire? Pitster or OGM front
This is a discussion on Widest tire? Pitster or OGM front within the Mini-Motards forums, part of the General Talk category; I have an older RCM front end on my bike. But it is essentially the same as the pister pro, ogm type with the invert ...
Results 1 to 6 of 6
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    I have an older RCM front end on my bike. But it is essentially the same as the pister pro, ogm type with the invert forks. Can someone tell me the widest tire you can run between the forks on these? I know I can run safely the 110/90-12 on a 1.6" rim. I now have 2.5" wide rims and wondering if I can get a 120/70-12 in there. It is for street riding, not racing.
    boonacka's Avatar
    Mar 2006
    Re: Widest tire? Pitster or OGM front
    if your running the fork guards, its a goo dchance they will rub. I run a 1.8 front rim with a 100/90 12 dunlop tt92 and it clears. that size may be your best bet. as a matter of fact i would run a 120/80-12 on the rear 2.5 rim. thats what the nsr's and nsf's run with that specific tire from the factory.
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Quote Originally Posted by boonacka
    Won't be running the fork guards and a 110/90 fits in there today with room to spare on a 1.6" rim. Question is will it work on a 2.5" front rim too? Going to have to keep the 120/70 rear since that is what I purchased. I do have a 110/90 as well but I'd prefer the fatty on the front too.
    boonacka's Avatar
    Mar 2006
    you know what, i did use a 120/70 micheline pilot on a 1.4 front before. fit fine. sidewall was pretty high but it fit.
    thats it right there on my old bike-
    scottiedawg66's Avatar
    Oct 2007
    Petaluma, Ca
    im running the kenda 110 / 70 12 and it BARELY clears I had to remove a fork guard. FWIW the kenda k761 is a pretty good cheap tire.
    magiksc's Avatar
    Oct 2006
    Somewhere between Heaven and Hell... Hemet/Provo
    how wide are your triples? That is a big factor. What rings are you using? I'm looking for some for my Motard.
110/70-12 1.60 rim
110/70-12 pit bike
can i fit a 120/70-12 on the front of my pitster x4r?
ogm pit bikes
widest tire for z50r
widest tire on a 1.60 rim
widest tyre on 1.6 rim
will a 110/90/12 fit on a 2.5
