YSR Extended swingarm
This is a discussion on YSR Extended swingarm within the NSR50, NSF100F, MB5, NS1 and RCV Mini forums, part of the General Talk category; Hello, just joined the site. Was wondering is anyone could give me some info on options for extended swingarms? Either aftermarket or stock extended. Thanks ...
Results 1 to 9 of 9
    flashsj's Avatar
    Feb 2009
    Hello,
    Thanks
    Joe
    shawnbassett26's Avatar
    Feb 2008
    Orlando FL
    Re: YSR Extended swingarm
    There are a few aftermarket extended swing-arms. But all are discontinued to my knowledge. But you may be able to find one second hand.
    But here is a few. There TRC is the cheapest. The JLF and CWR were $500+ when they were available.
    Team Calamari Racing
    JLF
    CWR Performance.
    Id recommend stretching it your self for finding some one to help you. Iv done quiet a few and its not that hard. The stock arm (as you know) is way too short. Depending on your set up a +1 1/2" - 3" is good. I wouldn't go over 3".
    Hope i helped.
    ~Shawn
    DESMINI 448R
    flashsj's Avatar
    Feb 2009
    do you have some pics of a stock extended?
    Feb 2008
    Orlando FL
    Here is a few pics for ya.
    YSR CWR swing arm. I made a few custom carbon parts for.
    Here is about a +2" YSR OEM Swing-arm.
    Here is a +3" YSR swing arm. I did not do the stretch, it was perviously done buy someone eles. I added a TRC swing-arm brade (that i under braced) , im boxing it in for a friend. Its not done but will be powder coated satin balck when it finished. But here is the idea.
    ~Shawn
    DESMINI 448R
    flashsj's Avatar
    Feb 2009
    Thanks
    Guess i'll try to extend mine.
    Emdoubleyu's Avatar
    May 2011
    Vancouver, BC
    How do you contact JLF Racing? Any idea where one would track down the longer OEM swingarm?
    Blackbird2xx's Avatar
    Sep 2008
    Nashville, TN
    try ysr50.org he should have some good info, also tcr carries a longer swinger for a ysr. I think though that ysr50.org does have the info on jlf. hope that helps
    is a 4 stroke God
    fireman_343's Avatar
    Mar 2007
    Blacklick Ohio
    Quote Originally Posted by Emdoubleyu View Post
    Check your PM... I've got his email
  10. #9
    Caisha's Avatar
    Apr 2017
    I'm new to the site. I had a year 50cc I used to fly around on. I'm 5'1 85 lbs and one day riding to work in the rain I ended up in an accident. A car cut off the truck infront of me so he hit the brakes hard and so did I. My back tire lifted up and over forcing me to jump off before I went head first into the trucks bumper.
    My question is I want to buy another after 10+ years but I'd like to figure out a way to make sure this doesn't happen again. I a guessing it was due to sliding on the wet pavement and the short wheelbase. Does anyone think getting an extended arm put on the new one I get, will make it unlikely to have this happen again or if it won't really help and it was my fault for using the front brake too much.
    Thank you for the help. I guess any suggestions on any other bikes would help. I'm a woman and don't want to ride with the big boys. I drive city, need a low, light bike, but enough power to get me up to 80 for short periods occasionally.
custom swingarms in orlando
custom yamaha ysr
custom ysr
custom ysr50
yamaha ysr extended swing arm
yamaha ysr extended swingarm
ysr 50 extended swingarm
ysr 50 swingarm
ysr swing arm
ysr50 extended swingarm
ysr50 swingarm
