NSR50 Swingarm Length
This is a discussion on NSR50 Swingarm Length within the NSR50, NSF100F, MB5, NS1 and RCV Mini forums, part of the General Talk category; I've got an NSR50 shock I'm retrofitting to a YSR frame (modifying the swingarm and upper shock mount). The motion ratio between the YSR and ...
Results 1 to 4 of 4
    sprintcarfan's Avatar
    Apr 2012
    I've got an NSR50 shock I'm retrofitting to a YSR frame (modifying the swingarm and upper shock mount). The motion ratio between the YSR and NSR swingarms appear to be different, just from what I can tell from pictures and comparing the spring rates. Can someone measure from the swingarm pivot to center of axle slot, and swingarm pivot to shock mount hole for me? Thanks in advance.
    John Martin
    87 YSR80
    johnson05's Avatar
    May 2009
    Looks to be about 10.3 and 20.4 cm. Thats just using a tape measure and not a vernier caliper or anything.
    Apr 2012
    I found a Japanese site selling used NSR50 swingarms with some dimensions. They are saying (if the translations is correct) swingarm pivot to axle is 41.5cm which sounds right, the YSR swingarm is 37.5cm. 10.3 sounds right for the shock to swingarm pivot dimension, but not the pivot to axle dimension?
    John Martin
    87 YSR80
    johnson05's Avatar
    May 2009
    Sorry I forgot to measure the total swing arm length. The measurements I listed were from the pivot point to the top and bottom of the shock. Total length should be longer than stock if you plan on a beefier motor. The placement of the shock pivots however will be crucial.
  1. Length of a +5 swingarm ??
    By Tibbs in forum CRF50
    Last Post: 03-10-2012, 11:45 AM
  2. klx 110 swingarm length vs kx60 length???
    By FTGraffix in forum KLX110, DRZ110, TTR90
    Last Post: 09-23-2010, 05:00 PM
  3. swingarm length?
    By crawl779 in forum KLX110, DRZ110, TTR90
    Last Post: 06-06-2010, 08:08 PM
  4. ZB50 shock length VS older NSR50 (non res) shock length
    By shawnbassett26 in forum 1988 ZB50 and ZB Import Replica Bikes
    Last Post: 03-09-2008, 03:01 PM
  5. Swingarm length
    By sweetjeep in forum KLX110, DRZ110, TTR90
    Last Post: 08-30-2007, 07:36 PM
how to measure a swingarm length
how to measure swingarm length planet minis
nsr50 craigslist
nsr50 swingarm length
xr50 swingarm on ysr50
yamaha ysr 50 swing arm length
ysr 50 shock legnth
ysr cfr 50 swing arm
ysr size length
ysr swing arm width
ysr50 shock length
ysr50 swing arm how to extend
