Need some help Pleaseeee!!
This is a discussion on Need some help Pleaseeee!! within the NSR50, NSF100F, MB5, NS1 and RCV Mini forums, part of the General Talk category; I somehow lost my nsr manual and need to time my counterbalancer. Do I just line up the punch mark in the gear with index ...
Results 1 to 2 of 2
    tacoshell4's Avatar
    Aug 2007
    attleboro mass
    I somehow lost my nsr manual and need to time my counterbalancer. Do I just line up the punch mark in the gear with index arrow on case? when crank is at tdc? any help would be great. Thanks in advance
    Taco
    johnson05's Avatar
    May 2009
    I can't really remember if the crank is at TDC or not. Basically turn the crankshaft until the punch mark on the primary drive gear lines up with the arrow on the crank case. Then install the counterbalancer so that the punch mark on the balancer gear lines up with the other arrow on the crank case. If it is done properly the weight on the counterbalancer and crank shaft should always be opposite to each other.
  1. Low Hours DOHC PLEASEEEE
    By Twister773 in forum Bikes and Parts Wanted - All Makes
    Last Post: 12-09-2008, 12:44 PM
  2. help keep Cali's trails open. pleaseeee
    By AndRenner in forum Roost Area
    Last Post: 10-19-2007, 06:00 PM
how to set nsr50 balance shaft
nsr50 balance shaft
nsr50r balancer
nsr50r engine counter balancer
