ysr yz250 swap
ysr yz250 swap
This is a discussion on ysr yz250 swap within the NSR50, NSF100F, MB5, NS1 and RCV Mini forums, part of the General Talk category; Here's my build I hope to have it on the road early next year. I started on it about 5 years ago then my daughter ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: ysr yz250 swap
    ysr90's Avatar
    Feb 2009
    St. Louis MO
    ysr yz250 swap
    Here's my build I hope to have it on the road early next year. I started on it about 5 years ago then my daughter was born and toys weren't a priority anymore. Blew the dust off a few weeks ago and decided it was time to get it finished. It's a 1990 YSR, 95 YZ250 motor with WR250 stator/lighting coil, shortened KX85 forks with ninja 250 springs, scooter shock in rear with shortened ninja 250 spring (might find better shock still), vortex clip ons, ninja 250 radiator, modified micron RZ350 pipe, R6 rear sets (maybe), hand made 4" over swingarm, trail tech vapor, ninja 250 caliper up front, stock fairings unless I get lucky and can find a set of the R6 fairings.
    I'm going to run the pitster supermoto mag wheels so I can have a rear disc brake (and they look really cool) but they won't be back in stock until first part of December. So I'll have to wait until then to finish the front and rear brakes and swingarm
    Here's some pics of the progress
    is if you aint getting hurt you
    aint riding hard enough
    Maktastik's Avatar
    Apr 2013
    anthem AZ
    That is sick bud
    2006 Crf 250x
    fmf mega bomb, FMf ti 4 slip on, k&n air filter, excel rims and red spokes, hrc oversized bar clamps, protaper oversized bars, zeta unbreakable levers, trail tech vector computer, white plastics , true gel battery, smoked 8 led tail light
    2008 klx 110
    twobros m6, twobros intake, twobros tall seat, fox float mxr, kx 65 front end, chp clutch kit, xr50 pro taper bars, tb foot pegs and mount, bump start kit, black pro wheels
    ysr90's Avatar
    Feb 2009
    St. Louis MO
    Thanks I still have alot of work ahead of me on this one but it will be nice when it's done. I almost like not being able to buy off the shelf parts that way I get to be creative and make stuff work.
    Maktastik's Avatar
    Apr 2013
    anthem AZ
    Quote Originally Posted by ysr90 View Post
    Is there anything done to the motor or is it just stock
    2006 Crf 250x
    2008 klx 110
    ysr90's Avatar
    Feb 2009
    St. Louis MO
    It was rebuild by the guy I bought it from so probably just stock.
    Maktastik's Avatar
    Apr 2013
    anthem AZ
    We'll I hope it is going to go smoothly with that build I want to do some kind of build with my cr125
    2006 Crf 250x
    2008 klx 110
    Luckystar64's Avatar
    Feb 2007
    Brunswick, Ohio
    Looks sweet! --L*64
    is twist the wrist too feel the
    bliss
    ndubstuntz420's Avatar
    Mar 2012
    she is gonna be one nasty hand full sir.........i like your taste!
  10. #9
    ysr90's Avatar
    Feb 2009
    St. Louis MO
    I was off to a good start then had to wait for parts then I just had hernia surgery Thursday. I have a box of new parts sitting out there waiting for me when I'm healed up enough to get back to work.
    I'm currently searching for a better rear shock but having a hard time finding one with the correct spring rate. I have a ninja ex250 spring on that china shock. The spring rate is 440lb/in. All the pitbike shocks the length I need have 800lb/in + springs which are too stiff for what I need.
  11. #10
    jrotten's Avatar
    Jan 2007
    everett,wa
    What length shock do you need? maybe someone can help you out,if its posted
    82' z50r mod
    12' gasgas xc300
    80' tri-moto 125
    04' H.D. Nighttrain
    86' Vanagon Weekender
  12. #11
    ysr90's Avatar
    Feb 2009
    St. Louis MO
    Well I think I found a solution to my shock problem. I had a R6 shock on there but it was way to stiff then I bought that scooter shock. I'm going to order a new softer spring from race tech and put the R6 shock back on there. That scooter shock doesn't have any compression or rebound settings so I'll throw it on a shelf and maybe use it on a smaller project
  13. #12
    ysr90's Avatar
    Feb 2009
    St. Louis MO
    I also scored a brand new pair of black vortex clip ons for cheap so I'll be selling those silver ones if anyone is interested. They are 46mm and fit the kx85 and kx100 forks as well as the 98+ ninja zx6r
  14. #13
    swheels's Avatar
    Mar 2008
    Fayetteville Nc
    First off,KILLER BUILD!!! I am a firm believer in having a rear shock linkage system on the smaller bikes. The difference is night and day and worth it when done correctly. Good you found a softer spring, only means the linkage system setup ratio is good.
  15. #14
    ysr90's Avatar
    Feb 2009
    St. Louis MO
    Not sure if I'm going to use the linkage set up or not. I might order the softer spring and see if it works. If not I'll just mount to to the swing arm without the linkage.
  16. #15
    Richie95F0's Avatar
    Nov 2014
    Sunrise, Fl
    Loving the build. That thing is going to be scary
  1. ssr150- 155z motor swap,suspension swap
    By mxkid247 in forum Chinese/Import Minis - General Discussion
    Last Post: 11-05-2009, 10:56 PM
  2. 07 yz250
    By mxsx284 in forum Complete Bikes For Sale - All makes and models
    Last Post: 07-30-2009, 10:03 AM
  3. 07 yz250
    Last Post: 07-23-2009, 06:42 PM
  4. yz250 radiator
    By gage191 in forum Bikes and Parts Wanted - All Makes
    Last Post: 06-30-2009, 10:12 PM
  5. WTT 05 YZ250 for KLX/DRZ 110
    By Yamaha48 in forum Bikes and Parts Wanted - All Makes
    Last Post: 02-01-2009, 02:50 PM
2004 yamaha yz 250 engine
arm yz 250
ex250 ysr
inverted forks yamaha ysr 50
yamaha ysr50 engine swap
ysr 250
ysr yz swap
ysr yz250 swap
ysr50 engine swap
ysr50 fork upgrade
yz 250 swing arm swap
yz250 motor swap
