YSR50 cutting out at high rpm/WOT?!
This is a discussion on YSR50 cutting out at high rpm/WOT?! within the NSR50, NSF100F, MB5, NS1 and RCV Mini forums, part of the General Talk category; I've got a 1987 YSR50. Stock bore, tcr exhaust, mikuni/sudco carb with k&n air filter. After cleaning the carb, it starts, idles and runs beautifully, ...
Results 1 to 2 of 2
    Mitchell1789's Avatar
    Apr 2012
    I've got a 1987 YSR50. Stock bore, tcr exhaust, mikuni/sudco carb with k&n air filter. After cleaning the carb, it starts, idles and runs beautifully, but at high rpms, it cuts out and stutters almost like a rev limiter sometimes. Does it at a standstill and when riding under a load. Can accelerate pretty well but it really seems like when I give it over 85% throttle or so it just wants to break up. If you baby it and get to higher rpms, it cuts out until you reduce the throttle then it picks up again. Tried adjusting the air fuel screw with little to no difference, and the needle being in the middle clip seems to be best, one clip up(more fuel) and it breaks up at a much lower rpm/throttle, and one higher clip(less fuel) and it seems to be worse then original position in the middle. Any ideas? Running a b9hs. Also running premis and oil injection just to be safe(bike is new to me,didn't trust the injection) Thanks in advance!!
ID:	173045   Click image for larger version.
ID:	173046   Click image for larger version.
    is RACING
    PocketBikeRacingTsmmr's Avatar
    Mar 2011
    NJ
    You might have to play with the jetting..
    One of my bikes does this too but it took me so long playing with Jets just to get it running right that I don't want to mess with it anymore..
    I thought it would be the CDI box but I changed it and I stuck it the same issue ..
    MINI RACING @
    Hidden Content
    NJminiGP kidz at New Jersey Motorsports Park
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
  1. Top end cutting out.
    By SoMichSoldier in forum CRF50
    Last Post: 09-16-2013, 11:00 PM
  2. Help with cutting out
    By Psychoholic in forum CRF50
    Last Post: 01-02-2008, 01:59 PM
  3. 110 cutting out
    By Jbrownkyr1 in forum KLX110, DRZ110, TTR90
    Last Post: 10-04-2007, 05:28 PM
  4. Cutting out at high RPMs
    By fatcaaat in forum CRF50
    Last Post: 05-28-2005, 05:06 PM
  5. 50 is cutting out
    By aedwards07 in forum CRF50
    Last Post: 04-23-2005, 10:23 AM
