What size of timing chain needed for 125cc stroker kit xr100?
This is a discussion on What size of timing chain needed for 125cc stroker kit xr100? within the NSR50, NSF100F, MB5, NS1 and RCV Mini forums, part of the General Talk category; Hi there everyone, got a question for you people... I am doin a nsr convention to a xr100 motor thanks to team Quasimoto. I have ...
Results 1 to 6 of 6
    Akhonda86's Avatar
    Jan 2014
    Eugene,Or
    Hi there everyone, got a question for you people... I am doin a nsr convention to a xr100 motor thanks to team Quasimoto. I have purchased a Yoshimura 125cc top end kit, but it came with no timing chain. My question is what size of chain is needed for these 125cc kits? Do I also need any special guids for it as well? I'll post pics as the build comes together more! Thanks guys
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    If you're using the stock cam sprocket, you'll use the stock cam chain as well. Both cylinders are the same height, correct?
    - dirtbkr188 -
    Akhonda86's Avatar
    Jan 2014
    Eugene,Or
    I don't have the kit in front of me at the moment, but I believe it came with a cam sprocket... It also has a stroker crank! That's why I was wondering what size of timing chain to use. One would think they would include it in the kit
    is Dem Tins
    Pierce's Avatar
    Feb 2006
    Evanston Il
    You use the stock chain.
    is Tinkering
    mrrcx's Avatar
    Jun 2011
    Westlake Village, CA
    Does that kit use stock head or come with another?
    Akhonda86's Avatar
    Jan 2014
    Eugene,Or
    YOSHIMURA : YOSHIMURA Head (125cc) Kit Type-R [268-406-25A0]
    This is the kit here! It is the stage 3 kit has head, jug and crank and all the other parts...
  1. Xr100 Timing Chain Woes.
    By Daniel_1988 in forum Bigger Minis Forum
    Last Post: 12-10-2011, 04:12 AM
  2. timing chain
    By kawi15 in forum CRF50
    Last Post: 01-16-2010, 06:50 PM
  3. YX 150 Timing Chain needed ASAP!
    By FASTFREAK693 in forum Chinese/Import Minis - General Discussion
    Last Post: 05-22-2008, 06:59 PM
  4. Cam chain timing
    By Waldo in forum CRF50
    Last Post: 03-20-2007, 01:15 AM
  5. lifan 125cc timing cover question
    By suzuki2903 in forum Chinese/Import Minis - General Discussion
    Last Post: 01-23-2007, 10:13 AM
