04 RMZ250 Valve Clearance?
This is a discussion on 04 RMZ250 Valve Clearance? within the Off Topic forums, part of the General Talk category; Does anyone know what the valve clearances are on an 04 Rmz 250. Im going to check the valves tomorrow but can't find what the ...
Results 1 to 3 of 3
    mxracer25s's Avatar
    Mar 2007
    ANDOVER NJ
    Does anyone know what the valve clearances are on an 04 Rmz 250. Im going to check the valves tomorrow but can't find what the valve clearance should be set at. Any help would be appreciated. thanks
    five21racing's Avatar
    Oct 2007
    South Dakota
    Re: 04 RMZ250 Valve Clearance?
    search thumpertalk.com
    dood's Avatar
    Sep 2006
    Washington
    .005/.009 intake
    .007/.011 exhaust.
    I run mine on the tighter side.
Remove Ads
04 rmz 250 valve clearance
04 rmz 250 valve specs
04 rmz250 valve clearance
2004 rmz 250 valve adjustment
2004 rmz 250 valve clearance
2004 rmz 250 valve clearance specs
2004 rmz250 valve clearance
2004 suzuki rmz 250 valve clearance
2004 suzuki rmz250 valve clearance
2006 rmz 250 valve clearance
2006 rmz 250 valve specs
