car audio help
This is a discussion on car audio help within the Off Topic forums, part of the General Talk category; Originally Posted by xWHITEYx You think it might have anything to do with Ohmage on the sub? +1, if its not the same ohms it ...
Page 2 of 2 FirstFirst 1 2
Results 21 to 30 of 30
Thread: car audio help
  1. #21
    Sincityshooter13's Avatar
    May 2009
    Las Vegas
    Re: car audio help
    Quote Originally Posted by xWHITEYx
    +1, if its not the same ohms it will cause the amp to overheat/fry, we get customers all the time in our shop that did it them selves and it'll be wired for 2 ohms, when it supposed to be 1 or 4 ohms or vise versa
  2. #22
    507 brett's Avatar
    Jan 2007
    mt. pleasant, NC
    Re: car audio help
  3. #23
    xWHITEYx's Avatar
    May 2008
    The San Gabriel Valley, CA
    Re: car audio help
    Sounds like the subs ohmage to me. Check the speaker wiring. Sounds like its causing your amp to cut cause its either over powering the sub. Check this Crutchfield diagram for your application.
    Are you running one or two subs off a 1400 watt amp??? If your just running one i think that amp might be too much power unless the sub is wired to compensate the amp. You can always call Crutchfield too and they can talk with you about it over the phone.
  4. #24
    xWHITEYx's Avatar
    May 2008
    Re: car audio help
    Sounds like the subs ohmage to me. Check the speaker wiring. Sounds like its causing your amp to cut cause its over powering the sub. But Im not sure. Check this Crutchfield diagram for your application.
    Subwoofer Installation Guide
    Subwoofer Wiring Diagrams
    Are you running one or two subs off that 1400 watt amp??? If your just running one i think that amp might be too much power unless the sub is wired to compensate the amp. You can always call Crutchfield too and they can talk with you about it over the phone.
  5. #25
    507 brett's Avatar
    Jan 2007
    mt. pleasant, NC
    Re: car audio help
    thats how we wired it. but the sub has 4 positive and 4 negative terminals on it. so we have the + and - from the amp going to one set of terminals on the sub and then connected the other +s to -s on the sub. just like this pic, but theres more than 3 wires.
  6. #26
    cr rider428's Avatar
    May 2009
    Re: car audio help
    might be to little power or not enough
  7. #27
    xWHITEYx's Avatar
    May 2008
    Re: car audio help
    Quote Originally Posted by cr rider428
    I was gonna say that next too. I looked at the specs on the amp and its RMS rating is 80 watts @ 4ohms. Your sub is rated at 150-350watts. Maybe its not getting enough power. Also have you checked your remote line.
  8. #28
    bear321's Avatar
    Feb 2008
    TUCSON ,AZ
    Re: car audio help
    sorry buddy that is ur amp that went out. i work for the specialist and i see that all the time pyle is not good stuff it throws out bad bass that what cuzzes to fry amp.
  9. #29
    507 brett's Avatar
    Jan 2007
    mt. pleasant, NC
    Re: car audio help
    so purty much i need a new amp.
    alright well im confused with this Ohmage crap. SOO you guys pick out an amp for me, and tell me why. ill get it probably after my bday. price range like 0-200ish. i was lookin at the ma amps on audiowarehouse.com and sonicelectronix. but idk i dont wanna spend a bunch of money and still have the same problems you know..
  10. #30
    85atc70's Avatar
    Jun 2008
    Tucson, AZ
    Re: car audio help
    the ohmage on the sub.
    Its your amp.....also lol
