Hey not here to bash Pitster (I love my lxr) ...
But... my bike keeps eating rear axles..... thats right eating!!
I have bent countless rear lxr axles to the point that the bearings end up destroyed too... So I need some options???
Thanks
This is a discussion on LXR Axles within the Pitster Pro forums, part of the PM Supporting Vendors category; Hey not here to bash Pitster (I love my lxr) ... But... my bike keeps eating rear axles..... thats right eating!! I have bent countless ...
Thanks
Maybe they wouldn't break if you weren't jumping AX like catapult jumps with your pitter?!?
Originally Posted by LFC911
Thats how us Ohio boys do!!!
That was kind of funny didnt even look at it first.... $hit why not??? bbbbrraaaap !!
Originally Posted by williegbiker
Ya I thought your wife was gonna whoop your arse after you did it!
try a cr85, you will probably need to cut it down a bit
Originally Posted by gecko
was going to try that but they are 14mm axles the lxr is 15mm
and the crf150r are 17mm ..............................
kx85 is 15mm
Originally Posted by Matified
thats the one
2004 - 2010 kx85 14mm axles.............. ??? what year are you guys looking at??
14 front 15 rear..??Originally Posted by williegbiker
All the dealers/microfish that I keep looking at say 14mm rear...
when I helped develope the LXT14/17,, the first one used a kx85 rear wheel,, I am not sure what year it was?, But that one was 15mm axle.Originally Posted by williegbiker
I also used the front and made reducer shims because it was 14mm.
Dunno what you weigh bro but i am 97 kgs and i aint bent one yet. so whate are u doin that bends them so easily
I bent one , im only at like 70kg if that ...
Originally Posted by boxy
Force = Mass x Acceleration....... I must ride a little faster than you.![]()
I duno about that , he pretty fast![]()
HA HA Funny,,, Boxy was #2 qualifier in his 12 expert in Vegas !Originally Posted by williegbiker
oh and the question,, the kx85 axle IS 15mm on all models since 1998.
soften up the rear suspension compression. are you bottoming it out? what spring rate and shock combo are you using?
MY YZ 80 uses a 15mm year axle.
Mine is stock spring rate stock shock , no bottoming out here .
Only noticed when i pulled wheel off , seemed to of messed up all my bearings... dont want to put new bearings in till i get a better axle in there .
Will the kx85 ones need abit of work ? cut down and rethreaded etc?
