Pitsters 140!!
This is a discussion on Pitsters 140!! within the Pitster Pro forums, part of the PM Supporting Vendors category; The Pitster Pro 140 crate engines are the only 140 that now has the close ratio trans!! as well as the Daytona style ignition!! These ...
Results 1 to 10 of 10
Thread: Pitsters 140!!
    Matified's Avatar
    Feb 2008
    USA
    Pitsters 140!!
    These things kill the older style granny low first gear 140 engines!!
    add the 146 and cam and you have an engine that rips!
    21017's Avatar
    Oct 2010
    Re: Pitsters 140!!
    Price for complete engine?
    Matified's Avatar
    Feb 2008
    USA
    Re: Pitsters 140!!
    chriswing015's Avatar
    Sep 2010
    Re: Pitsters 140!!
    so these things are really worth it?? or should i just spend the extra 200 on a lifan 150?? these things are soo cheap i wanna just buy it and see how she rips... ill be droping it in a crf70... its got an 88 in it no with mx swingarm and ****ty fastace forks.. how much better would the 140 be?? thanks
    jkill351's Avatar
    Sep 2010
    Re: Pitsters 140!!
    i just got the pp 125. the salesman told me that the 125 has the closer trany not the 140. they can be purchased for 349 or 379. my 125 sounds really mean. lots of power. if you have a stock crf i hope you have a welder ready. the mount for the oil cooler needs to be mounted someway. i cut the nipple off and welded it behind the key. finding a spot for the ignition is tough. i recomened building a box and placing it near the motor mount.
    you will need a new twist throttle. the stock crf throttle will not open the carb enough for full throttle( and thats if you can find a way to take up the slack in the cable) i modified a mountain bike adjuster.
    Matified's Avatar
    Feb 2008
    USA
    Re: Pitsters 140!!
    Quote Originally Posted by jkill351
    The 125 does have the close ratio trans, and higher compression piston, and a few other details, the 140s just came in with the close ratio trans.
  7. #7
    maztech89's Avatar
    Feb 2010
    Berlin, PA
    Re: Pitsters 140!!
    So what kinda jetting should I be running at 1800'? Also what would my best upgrades for this motor be? I am finishing up the install this week, just need to get my oil cooler mounted ( lines supplied are too short) so I gotta find some hose for now. I'm excited to ride it but still need a bunch more parts chassis wise to do so like pegmount and brake pedal that clears clutch cover.
  8. #8
    p3racer's Avatar
    Sep 2003
    FLORIDA
    Re: Pitsters 140!!
    4 SPEED? wonder how a Take +R head would work on it?
  9. #9
    solorider81's Avatar
    Feb 2008
    lbk
    Re: Pitsters 140!!
    whats better the 125z or hp125????
  10. #10
    Garn#627's Avatar
    Mar 2010
    Grantsville Utah
    Re: Pitsters 140!!
    I've got one they rip and shift really smooth!
carb jetting on a pitster 140 engine
gpx 140 engine review
gpx 140cc
ignition cover gpx moto
pitster 140 engine jetting
pitster 140 in crf
pitster pro 140 crate motor how to wire
pitster pro 140 review
trail 70 motor
trail 70 replacement motor
xr50 brake pedal clears 140 engine
z 140 web
