Fork removal question!!! need help
This is a discussion on Fork removal question!!! need help within the Roost Area forums, part of the General Talk category; Hey guys i removed top clamp and pulled tubes out, but i am having trouble with the center bolt holdin the lower section that the ...
Hey guys i removed top clamp and pulled tubes out, but i am having trouble with the center bolt holdin the lower section that the fork tubes slide through i have the nut off and the other piece out, how do i get this piece out??? here is a pic. there are bearings which i cant seem to get out
can anybody tell me how to get that OUT of my frame!
06-08-2010 12:21 AM
Re: Fork removal question!!! need help
it should have slits for it so you usually just take a hammer and a screwdriver, and hit it until its loose then just unscrew it
i have already removed that piece your talking about, it came out, and now theres nothing but bearing i believe holding it in, i thought it would slide right out but nothing, i hit it with a hammer soft a few times, and it didnt do anything, im not sure what my next step is, i cant seem to pull that top bearing out
BUMP! really trying to get this figured out today...its drivin me nutts
- You may not post replies
- You may not edit your posts
Forum Rules
