X4R Pitster bore kit????
This is a discussion on X4R Pitster bore kit???? within the Roost Area forums, part of the General Talk category; Im putting a TB 170cc V2 kit w 28mm carb on my 160X4R pitster and i need to know what the clearance specs on the ...
Im putting a TB 170cc V2 kit w 28mm carb on my 160X4R pitster and i need to know what the clearance specs on the valves are, how to set the timing, jetting on the 28mm carb, if i can get the right pipe intake to keep the carb facing towards the rear and where to get it, and some torque specs on the bolts....
11-08-2008 04:07 PM
Re: X4R Pitster bore kit????
i dont think the scut 170 will work with the 160 crank, the pin will fall below the cases.
Yeah TB sent me the cylinder that works to make it a 184cc... They just got them in....
ok well good luck starting it, we broke every case we had trying to start the 177 untill we got the takegawa decomp cam.
we have the adaptor boots to fit your stock intake and run your carb to the rear
you may need a heat spacer too
TBolt USA, LLC » Pitbike Engine Parts » CARB KITS » 26mm intake ADAPTOR boot
the head torque is 110 in lbs
the timing is just like a 50
I just need the clearance on the valves??
Originally Posted by
ja9r1e4d
i just need the clearance on the valves??
00.3 intake and 00.4 exhaust
.003 on intake and .005 on exhaust.
- You may not post replies
- You may not edit your posts
Forum Rules
