just got a KLX and its leaking gas from the carb
This is a discussion on just got a KLX and its leaking gas from the carb within the Roost Area forums, part of the General Talk category; what is making my carb leak gas so bad? There is a little nipple on the carb below the airfilter thats gold and is crimped ...
Results 1 to 11 of 11
    nugent_crai's Avatar
    Apr 2007
    huntington, NY
    what is making my carb leak gas so bad? There is a little nipple on the carb below the airfilter thats gold and is crimped and it looks like the gas is coming out of there, but my whole house stunk when I woke up this morning!! gas was everywhere!
    is reviving PM one post at a
    time.
    jdmp's Avatar
    Jun 2005
    pinellas FL
    Re: just got a KLX and its leaking gas from the carb
    float bowl is stuck. Try tapping on the bowl with a screwdriver or you can take the carb off and unstick the float. It leaks when the gas is off?
    Apr 2007
    huntington, NY
    no i left the gas on... i always do
    Is this going to be an ongoing problem?
    Pitster's Avatar
    Apr 2005
    Lindon, Utah
    Quote Originally Posted by jdmp
    What he said.....
    Also even if the gas is on and the float level is correct, it shouldn't leak, or at least it should be very very little anyway, like maybe when you are transporting it, but not when its just sitting.
    Always good to turn tha gas off when not in use.
    Apr 2007
    huntington, NY
    well i just bought the bike last night.
    Started it right up, thew it in my truck (forgot to shut the fuel off)
    Started it up at home and drove it into my garage ... I didnt shut off the fuel.
    I woke up this morning to find that the bike leaked gas all over the garage floor (it was a slow drip) and took the paint right off the floor!!!
    stunk up the whole house through the garage!
    Pitster's Avatar
    Apr 2005
    Lindon, Utah
    Quote Originally Posted by nugent_crai
    Sounds like your float is just not seated all the way down.
    Did you buy it new, the dealer should adjust the float for you.
  7. #7
    Apr 2007
    huntington, NY
    nah, its an 07 with a 143 kit and a bigger carb, bought off some kids out east
  8. #8
    time.
    jdmp's Avatar
    Jun 2005
    pinellas FL
    turn off the gas and just take the float bowl off. adjust the float and see if it stops leaking
  9. #9
    JIMMY's Avatar
    Jun 2004
    temecula ca
    Try tapping the float bowl with a wrench.
  10. #10
    PitRacerVince's Avatar
    Oct 2008
    Lancaster, CA
    Id say the float too I had that problem on my sons bike, but that crimped nipple doesnt sound right. Post a pic if u can that sounds weird to me. Hope u enjoy ur new ride!
  11. #11
    Thormx115's Avatar
    Jul 2008
    Fairfield, CA
    its probably the float needle and seat. even if the float bowl height is correct it will still leak fuel if the needle and seat and not seating togeather. take the float bowl off and see if the needle is sticking at all. also turn on the fuel with the float bowl off and push the floats up but gently, if its still leaking thats what you need to replace the needle and seat
2007 klx 110 leaking gas
kawasaki klx 110 carburetor leak
klx 110 carb leaking
klx 110 carburator leaks gas
klx 110 leaking carb
klx 110 leaking gas
klx carburator leaks gas
klx110 driping gas
klx110 leaking gas
when i turn the gas on for klx 110 my gas start to leak
