6 volt lighting question.
This is a discussion on 6 volt lighting question. within the Scooter Forum forums, part of the General Talk category; Bike 78 yamaha chappy. just installed new headlight assembly. New head lamp new tail lamp. burnt out immidiately when I upped the rpm's this bike ...
Results 1 to 8 of 8
    is tinkering in the shop
    Good Looking Ugly Guy's Avatar
    Feb 2010
    Ritzville Washington
    just installed new headlight assembly. New head lamp new tail lamp. burnt out immidiately when I upped the rpm's this bike is supposed to have blinkers but they are not currently installed. is the issue possibly due to the lack of additional lamps?
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    As a former chappy owner, you have the classic symptom I had...the regulator is not regulating anymore and allowing full voltage.
    Feb 2010
    ty fat cat So I assume I can run w/o signals then
    joeburt1's Avatar
    Aug 2013
    Houston Texas
    wow, glad I saw this...I bought a chappy a few weeks ago, got it running (not too well but still working) maybe I will change out the rectifier before I buy lights...
    mikesbike's Avatar
    Mar 2012
    San Diego, Ca
    I think all of these 6 volt bikes rely on a fully charged battery to absorb the spikes
    its well known that if you have no battery, or a really bad one bulbs start to blow out quickly
    best to stock up on them too, dratv is where I get them from
    sometimes they can last months, years
    other times you can just burn out a good one couple times in a row
    may be quality control
    also make a habit of keeping 6 volt bikes on a battery tender made for 6 v and super low amp setting
    will just prevent light blowouts later
    1970 CT70
    1979 CT90
    1981 C70
    2010 Zuma 125
    2012 KLX 250S
    Hidden Content
    is getting called a greaser
    because of how his Z50 looks
    dventu's Avatar
    Jan 2014
    California
    I agree with mikesbike. If you don't have a battery then the bulbs with keep blowing that is what happen to my 12v system with a new rectifier/regulator and stator.
    2smoke's Avatar
    Jun 2015
    Sorry guys, the chappy doesn't have a regulator, it uses all the lites 2 keep jus 7.2v in the system so nuthin blows, if ya blow the headlite, the taillite will go nxt, then the speedo & indicator lites in the speedo, then the blinkers if ya use em, it happened 2 mine, but ya do hafta keep a good battery in it, that does absorb the spikes that a high rpm will sumtimes cause, hope this helps ya out, if ya need ne bulbs, amazon has all ya need 4 cheap!-------2smoke
    is Electrical
    JPardue's Avatar
    Nov 2013
    Florida
    Builds a 6 Volt AC headlight Voltage regulator for Yamaha DT's and wants to make it plug-in-and-ride for the Chappy.
    If a Chappy owner will work with me to get the plugs and wire colors right, and will send a photo or two where it can fit, you can score a free regulator.
    Jon Pardue
  1. Lighting Question
    By BlackHornet in forum Mini-Motards
    Last Post: 05-07-2011, 02:45 AM
  2. Does this lighting kit require a volt regulator
    By LANTIX09 in forum Chinese/Import Minis - General Discussion
    Last Post: 12-12-2009, 05:42 PM
  3. scratched 6-volt 50cc head question
    By mexicanyella in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-04-2008, 04:34 AM
  4. 6 Volt points Question
    By MAZZ77X in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 06-26-2007, 10:43 AM
  5. Dumb question about 6 volt motor
    By supernes550 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-26-2006, 12:38 PM
6 volt scooter headlight
chappy headlight bulb
how to replace a chappy headlight
new chappy headlight install
replacing chappy headlamp
yamaha chappy 50 rectifier location
yamaha chappy headlight
yamaha chappy headlight bulb
yamaha chappy headlight not working
yamaha chappy lights not working
yamaha chappy voltage regulator
yamaha scooter 6 volt
