Motor options
Motor options
This is a discussion on Motor options within the Scooter Forum forums, part of the General Talk category; I know this is a few years old... Was that motor a semi auto? if so, would you happen to know what motor that is ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By dirtbkr188
Thread: Motor options
    is Boost or Bust?
    racer rex's Avatar
    Jan 2011
    Pittsburgh,Pa
    Motor options
    Was that motor a semi auto? if so, would you happen to know what motor that is exactly?
    I'm trying to find a 125cc to 250cc that's semi auto and electric start with the shift pattern either all up or all down and without reverse.
    i did find this.... but its uk
    Lifan 125cc Semi Auto. Electric Start Pit Bike Engine B/S
    thanks
    is zero fox given
    rustynuts's Avatar
    May 2014
    Norcal
    Check out my Pitster mini monster zb50 thread: Hidden Content
    is Texas Made
    Htx_klx42's Avatar
    May 2015
    Houston
    Quote Originally Posted by rustynuts View Post
    that has reverse. They do have the Lifan with semi 4 up, no reverse. BUT it's only kick start.
    is Boost or Bust?
    racer rex's Avatar
    Jan 2011
    Pittsburgh,Pa
    Quote Originally Posted by Htx_klx42 View Post
    Thanks guys.
    I'm putting an electric shift on something and I wouldn't be able to use the ones with reverse. i need to have a shift pattern all up or all down..... just thought of this... unless you have to unlock a pin or something in the trans allowing you to go into reverse. Does anyone know how revers works on those motors? just drops from neutral to reverse as if it was 1st gear or shift to neutral, pull a cable then reverse?
    Another thought is to get the kick motor you said and swap to electric start... don't know if you can... anyone know?
    I just found this btw... $150 more than i wanted to spend
    Lifan Engine Kit 125cc Auto Shift 4? Engine Electric Start Fits Honda E Start | eBay
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    I had a Chinese 110 quad with the reverse being in the 1st gear position R-N-1-2-3
    As far as converting kick to electric start, the cases and left side covers are different, to accomodate the flywheel/one-way clutch and starter motor chain. The stator is usually inside the left side cover, with the flywheel mounted on the crank.
    - dirtbkr188 -
    is Boost or Bust?
    racer rex's Avatar
    Jan 2011
    Pittsburgh,Pa
    Wasn't sure if it was a bolt on bracket or the entire left side case.
    is Boost or Bust?
    racer rex's Avatar
    Jan 2011
    Pittsburgh,Pa
    Motor options
    Does anyone have knowledge of where i can find a 125cc to 250cc semi auto with electric start?
    I started this another thread and figured i'd stop high jacking that thread.... here's what was discussed.... also the motor doesn't have to be horizontal
    Quote Originally Posted by racer rex View Post
    Thanks guys.
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Here is a pic of a bottom-mount e-start engine case set with a conventional left side ignition cover, you can see the gap where the backing plate for the starter motor goes.
    racer rex likes this.
    - dirtbkr188 -
  1. mod 110 motor options?
    By chris140 in forum KLX110, DRZ110, TTR90
    Last Post: 12-29-2010, 02:00 PM
  2. Motor options
    By Marconi22 in forum KLX110, DRZ110, TTR90
    Last Post: 12-10-2010, 06:53 PM
  3. motor options?
    By chris140 in forum Chinese/Import Minis - General Discussion
    Last Post: 12-07-2010, 04:34 PM
  4. motor options
    By SCAR8 in forum CRF50
    Last Post: 12-11-2006, 02:08 PM
  5. ? & Options about my motor.
    By -eagle- in forum CRF50
    Last Post: 01-05-2005, 04:21 PM
