Kx65 Sprocket Clearance
This is a discussion on Kx65 Sprocket Clearance within the Sik Tendencies forums, part of the PM Supporting Vendors category; hi guys i've got your kx65 rear brake kit on my bbr klx, the brake and wheel are mounted fine but it looks as though ...
Results 1 to 8 of 8
    is a neat guy!
    chris140's Avatar
    Apr 2008
    South West UK
    hi guys i've got your kx65 rear brake kit on my bbr klx, the brake and wheel are mounted fine but it looks as though the sprocket and chain aren't going to clear the chain guide? even with the wheel adjusted all the way forward and back on the blocks... obviously the stock kx sprocket is far too big but there isn't much room for anything else, been told a 39t will clear but can you advise please?
    siktendenciesracing's Avatar
    May 2007
    Los Alamitos, CA
    You can go as low as a 38 sprocket and we actually run a 44 tooth rear sprocket on our race bikes with the Sano 3 piece billet swingarm. Talon has as low as a 41 tooth sprocket; http://www.talon-eng.co.uk/products....how=&bike=1221 ,,, also Vortex, PBI, Rocket sprockets all will have the 39 tooth sprockets and higher.
    NOTE: If you are wanting to run the bigger sprockets we have in the past made an adapter spacer that moves the chain guide up so that it doesn't get in the way of the bigger sprocket. We ran a 46 tooth before.
    is a neat guy!
    chris140's Avatar
    Apr 2008
    South West UK
    thanks guys, going to call talon monday morning. don't suppose you have any of the adapter spacers for sale at all?
    cheers
    May 2007
    Los Alamitos, CA
    Quote Originally Posted by chris140 View Post
    cheers
    each swingarm would be different due to the bolt patterns being different. You just have to take some aluminum or steel and fabricate a one off piece.
    NOTE: I run a 44 tooth on all our race bikes (12 bike) and with the Sano 3 piece billet swingarm and chain guide need no modification.
    is a neat guy!
    chris140's Avatar
    Apr 2008
    South West UK
    ok will wait for the sprocket to arrive and see how we go. there's another lad over here with the same set up that says he runs down to a 39t with no problem
    thanks again
    RockingRock's Avatar
    Apr 2012
    Hi...
    I normally don't really interrupt the discussion where I am not needed to say anything but I really liked the way you people assist others. this is remarkable and really appreciated one...
  7. #7
    koby686's Avatar
    Apr 2008
    we scrub harder in california!
    I run a 44t on my BBR with the the str adapter no modifications or anything works perfect
  8. #8
    is a neat guy!
    chris140's Avatar
    Apr 2008
    South West UK
    39t talon and it all clears a treat just need to ride her now lol
11 tooth sprocket for kx 65
2008 klx 65 rear sprocket teeth stock
kx 65 sprockets
kx 65 stock sprocket size
kx65 36 rear sprocket
kx65 forum chain sprocket
kx65 sprocket
kx65 sprocket size
kx65 sprockets
kx65 stock sprocket sizes
sprockets for kx 65
what are the stock sprockets for a 2008 kx65
