KX65 front disc brake adapter kits available with Line and Wave Rotor!
This is a discussion on KX65 front disc brake adapter kits available with Line and Wave Rotor! within the Sik Tendencies forums, part of the Vendor Area category; I have 7 more KX65 200mm wave rotor's available and 10 more wave rotors for the KLX110 Marzocchi hubs, so if you where going to ...
Results 1 to 12 of 12
    siktendenciesracing's Avatar
    May 2007
    Los Alamitos, CA
    I have 7 more KX65 200mm wave rotor's available and 10 more wave rotors for the KLX110 Marzocchi hubs, so if you where going to run the Galfer/STR wave rotor get them while they are still available because we won't be reordering the rotors so after there gone they are gone forever.
    We are selling the KX65 STR Adapter bracket/Galfer STR Wave Rotor (KX65 or Marzocchi)/and Black or Red Brake line for $199.99 plus $7.50 shipping (Retail is $229.99 + $7.50 shipping w/Black line and $239.98 with Red line + $7.50 shipping.
    Thanks,
    Gary
    STR
    Please send payment to garymarshall254@hotmail.com
    May 2007
    Los Alamitos, CA
    Bump,, just sold one of the KX65 rotors,, so one less now.
    Gary
    STR
    mx756's Avatar
    Mar 2005
    I am very interested in a KX65 adapter brake kit for my ssr 160 with knock off marzocchi forks. i just need to know which rotor to get, the marzocchi or the KX65. im pretty sure i need the kx65 because it is a 4 bolt pattern (like on my 160 front hub and the marzocchi is a 5 bolt. i just want to clarify before purchasing. i have a master cyclinder just still need to find a caliper on ebay.
    May 2007
    Los Alamitos, CA
    Quote Originally Posted by mx756 View Post
    Show me a picture of the front wheel and I can tell you what hub you have, thanks.
    Thanks,
    Gary
    STR
    mx756's Avatar
    Mar 2005
    here ya go. thanks for your help.
    May 2007
    Los Alamitos, CA
    You need the STR CR85 front disc brake adapter kit which you run the CR85 front caliper and any YZ/KX/or RM style master. The above Wheel is the SSR oem wheel that isn't the same bolt pattern as the KX or the KLX110 marzocchi wheel so neither rotor I have will work. I think the rotor on your front wheel is a 220mm rotor and the CR85 adapter uses that size rotor (Made for the Pitster LXR rotors which should fit your hub if you want a wave rotor)
    Here is a pic of the kit:
  7. #7
    mx756's Avatar
    Mar 2005
    Bought a KX65 front brake caliper on ebay. just need to know which rotor to get from you in your kit.
  8. #8
    May 2007
    Los Alamitos, CA
    See if the person you bought it from will sell you a CR85 Front caliper, or call pitster/ssr/pirana to see if they have a 200mm rotor that will fit on your hub then you would be able to use the KX65 front disc brake adapter bracket (Cause the KX65 adapter bracket uses a 200mm rotor) if not you would have to use a CR85 caliper with the CR85 STR front disc brake adapter bracket.
  9. #9
    mx756's Avatar
    Mar 2005
    yes i can get a 200mm rotor that will fit my hub from tbolt. that way i can use the kx65 caliper i purchased. so all i would need buy from you is the mount and the brake line in black.
  10. #10
    May 2007
    Los Alamitos, CA
    Ok,, that makes me feel better that you don't have to go through the hassle of changing out calipers. My paypal is garymarshall254@Hotmail.com and the KX65 adapter (Retails for $99.99) with black brake line (retails for $59.99) but together as a kit goes for $149.98 plus $7.50 shipping so total is = $157.48
  11. #11
    mx756's Avatar
    Mar 2005
    thank you for your patience and help. much appreciated. i am sending the money now via paypal. i have 2 more buddies with ssr 160's looking to do the same thing so might be in touch again.
  12. #12
    May 2007
    Los Alamitos, CA
    Still available,, get them before vegas gets here cause I only have a couple more rotors left of the KX65 and KLX110 marzocchi wave rotors for these kits! $199.99 plus $7.50 shipping! Sale is till May 5 2012!
Sponsors
  1. Str Front And Rear Disc Brake Adapter Kits For Lxr On Sale!!
    By siktendenciesracing in forum Sik Tendencies
    Last Post: 09-30-2011, 02:28 PM
  2. KX65 A-style Rear Disc Brake adapter kits on sale till Feb 28th!!
    Last Post: 03-10-2010, 01:29 PM
  3. KX65 Rear Disc Brake Adapter kits!!
    Last Post: 01-13-2010, 11:37 PM
  4. KX65 front disc brake adapter and brake line
    By stunt-ur in forum KLX110/Midsize Parts for Sale
    Last Post: 06-19-2008, 11:55 AM
  5. BIG MINIS Is now carrying STR front disc brake adapter kits
    By siktendenciesracing in forum Roost Area
    Last Post: 05-30-2008, 08:57 PM
02 kx 65 front brake system
200mm wave brake rotors
350x kx front caliper
braking rotor for kx65
cr85 front brake diameter
disc brake adaptor is to post
disc rotord rm 65
front brake disc for kx65
is to is brake adaptor 200mm
kx 65 brake
kx 65 front brake caliper
kx65 big brake kit
kx65 front brakes
kx65 front disc
marzocchi forks with kx 65 brakes
