KX65 rear brake on FOES hub?
This is a discussion on KX65 rear brake on FOES hub? within the Sik Tendencies forums, part of the PM Supporting Vendors category; Hi guys,
Sry I posted a similar thread in the general forum before I realised i should have posted here!! However!
I got myself a ...
Hi guys,
I got myself a KX65 rear caliper and master cylinder and I should be buying the mount kit from Gary. Before I do I just need to check.... I have a Foes billet hub on my rear wheel setup which run mountain bike rotors, I know I can make the caliper work on the thinner rotor but the question is will the rotor itself be strong enough for the greater clamping force of the bigger caliper?? I'm hoping to avoid having to get a KX65 wheel if poss.
Thanks. Steve.
01-29-2012 04:31 AM
we have used the formula rotor on the front disc brake adapter kit that uses the KX65 front caliper with no issues with that set up but I don't know how that rotor you have will work with the Rear KX65 rotor. NOTE: The spacing for the kit is for a KX65 rear wheel as well as the size a rotor the KX65 wheel uses (180mm rotor on KX65 rear wheel).
Gary
STR
I think this mountain bike rotor is 183mm, but what about the strength? Would the greater force of braking rip the bolt heads off, or bend the rotor somehow? Might just have to go for the 65 wheel by the sound of it.
The Rotor will not work with the KX65 adapter kit because the rotor will not fit past 180mm inside the caliper(So the extra 3mm will be rubbing on the caliper).
Will the kit work on a 155mm BBR rear rotor and hub?
no cause the rotor is too small and will cause the brake pad to wear uneven. Sorry
Gary
STR
get talon to make a new disc to correct size..???
- You may not post replies
- You may not edit your posts
Forum Rules
By Gixxer1K87 in forum Bikes and Parts Wanted - All Makes
Last Post: 04-07-2010, 06:06 PM
By jrotten in forum Bikes and Parts Wanted - All Makes
Last Post: 01-28-2008, 03:55 PM
By iskatealot33 in forum KLX110/Midsize Parts for Sale
Last Post: 01-14-2008, 10:44 PM
Last Post: 10-20-2004, 01:25 AM
By Dilligaf in forum CRF50
Last Post: 10-16-2004, 08:18 AM
how to adjust kx65 rear brake
how to adjust rear brakes on kx 65
how to change brakes on a 2004 kx65
how to change rear brakes on a kx 65
how to replace the brakes on a kx 65
kx 65 forum
kx65 forum
kx65 rear brake on pit bike
kx65 rear hub
kx65 used wheel hubs
sik tendencies kx 65 master cylinder
used kx65 rear brake disc
