z50 rear wheel on crf50? - Page 3
This is a discussion on z50 rear wheel on crf50? within the Stunt Minis forums, part of the General Talk category; Originally Posted by eichkay A 4.0 wide tire should clear fine ive got 3.5 rims and 120mm wide tires on my crf50 and chain clearance ...
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
Like Tree3Likes
Thread: z50 rear wheel on crf50?
  1. #31
    InfiniteReality's Avatar
    Oct 2009
    Lake Charles, LA
    Quote Originally Posted by eichkay View Post
    A 4.0 wide tire should clear fine ive got 3.5 rims and 120mm wide tires on my crf50 and chain clearance is good..
    Sweet, good to hear! Tire is due in Monday so I'll put it all together. Got the wheel, hub, brake and sprocket on bike now and all fits with a couple washers. Even use my 50stunt chain guard.
  2. #32
    Oct 2009
    Lake Charles, LA
    I'm sure I'll figure it out Monday when I put the tire on, but I'm curious since I have time to ask... Which half of the Z50 wheel goes on what side? This is how I have it now and I think it's right, but wanted to ask since I have a few days before hand and would rather do the tire install once. Thanks!!
  3. #33
    is Rocking a 88cc DOHC on 8's
    eichkay's Avatar
    Jul 2005
    Perth, Australia
    Valve side is on the brake hub side... Looks like you got it the correct way around
    20plus
    Fifty Riders
    Oct 2009
    Lake Charles, LA
    Cool, thanks again!
  6. #35
    eichkay's Avatar
    Jul 2005
    Perth, Australia
    Loving this tire/rim combo.. just need to upgrade the stock motor and get the rear pegs and 12 bar on now..
    20plus
    Fifty Riders
  7. #36
    Oct 2009
    Lake Charles, LA
    That's sick man, looks fun!
    I've been back and forth to go same route you did or go the 10" route... I almost bought the tires, but held off to see what the 10" wheel looks like. I have Z50 forks with a disc brake setup sitting on my floor right now and fixing to put those on to see how the wheel looks on the front and any clearance issues. Also have 50stunt triple on the way so I can run same bars I have now and I'll swap the HD springs and bushings to the Z50 before installing.
    Here's some pictures of the Kitaco 2.5" wheel with a 120/70 Zippy tire on it. How it sits right now, the clearance between the tire and swingarm is VERY close, but I also have right at 1/2" worth of adjustability further back.... I"m still undecided on which size wheels I want, but pushing for 10" right now. It'll also allow me to run a disc brake on the rear later down the road if I wanted. Damn choices and I need to order something ASAP so I can get this stuff back together and try it out!
    4.00x8 versus 120/70-10
  8. #37
    Banned
    110kawisaki143's Avatar
    Aug 2012
    How much would it cost to make a nice street bike 50 with those bigger wheels
  9. #38
    Oct 2009
    Lake Charles, LA
    Quote Originally Posted by 110kawisaki143 View Post
    Wheels are the same size as stock, but mine has been street legal for past couple years and I've rocked the stock wheels till now. The only thing you need is DOT wheels, all lighting, horn and that's about it. Maybe couple hundred in costs for everything.
  10. #39
    Banned
    Aug 2012
    Ok cool once I get my license I wana get a 50 street legalized. So where did you get those wheels?
  11. #40
    Oct 2009
    Lake Charles, LA
    I got a hell of a deal on the Kitaco wheel and tire on ebay for $61. Trying now to locate a front wheel
  12. #41
    PieterVP's Avatar
    Dec 2012
    Belgium
    what adjustments are necessary for a monkey/z50r front wheel, in the crf50 front forks? thanks
  13. #42
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    The Z50 wheel will not fit on the stock XR/CRF50 front forks, they are too narrow for the wider wheel. I used the Z50A front forks with the XR/CRF +1 HD fork legs and springs on the XR/CRF frame. It is a direct bolt-up, as seen on the bike below.
    - dirtbkr188 -
  14. #43
    PieterVP's Avatar
    Dec 2012
    Belgium
    just what i thought. Every monkey/gorilla front fork will work I guess. Thanks
  15. #44
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Actually, that's not entirely true, the front forks from the '68-'71 hardtail Z50a models have a taller steering stem and do not fit on the XR/CRF50 frames
    - dirtbkr188 -
  16. #45
    PieterVP's Avatar
    Dec 2012
    Belgium
    ok, many thanks !!
back wheel z50x
crf50 with z50 wheels
crf50 z50 wheels
honda xr50 forum
honda z-50 rear tire spacer
honda z50r taller wheels
largest rear tire on a xr50
z50 3.5 wide wheel
z50 rim
z50 wheels on a crf50
z50 wheels on crf
z50 wheels on crf50
