i've got a z50 rear wheel kicking around and from what i hear it fits without mods into a crf/xr swinger. the tire is much wider and the rim is solid (no spokes to break/get loose). has anyone done this mod? would it make circles harder?
This is a discussion on z50 rear wheel on crf50? within the Stunt Minis forums, part of the General Talk category; i've got a z50 rear wheel kicking around and from what i hear it fits without mods into a crf/xr swinger. the tire is much ...
Never tried, it. If you have the parts give it a go. Let us know how it turns out.
You can run a z50 rear wheel on a crf. I think you need to make one spacer, other than that its a direct swap. I bet you can run them tubeless if you run a bead of caulk between the 2 wheel halfs.
I was going to do this a while back but got my douglas wheels instead. The Z wheels are dirt cheap.
Not my bike.
Required email for classifieds: kelly_shea@charter.net
Yea man, CRF wheel is 180mm wide including spacers. Z50 wheel is only 168mm wide including spacers, so you need to add about a half inch of spacing to the wheel. EddieNewYork has tried it on his CRF50, so you could ask him which side he put the extra spacer on or if he needed to run two spacers. Circles are definately a bit harder on the 8" tires I had, but I am thinking with good 8" street tires it is probably not too bad.
I did it, you need to add about 1/2" of spacer (4 thick washers is what I did) to the chain side of the wheel/swinger, I cant answer your wheelie question though...
that looks sooooo effing coool!!!!!!!!!
im going to do this... you can get a 4x8 rear street tire here....
Honda Mini Trails Honda mini bikes and Honda Z50 Honda 50 Honda Minitrail NOS Parts and services Kitaco and Takegawa performance parts.
Part Z111
I did it using an XR70 swingarm...
- dirtbkr188 -
dirtbkr188- what tire is that? what size?
is there a fitment issue with the stock swinger?
do you wheelie it, if so what do you think?
I just bought a 70 swinger for mine, just need to weld the tab on and get a longer chain.. hopefully soonOriginally Posted by dirtbkr188
That is the same Kings Tire that you referenced above, Part #Z111. I didn't have a stock swingarm when I put the bike together, just the 70 one. I don't wheelie it, its a pavement/parking lot bike.Originally Posted by tech1234
- dirtbkr188 -
mine is set up front and back with chome mini trail wheels i had to make a spacer for the back and use a z50 front end
wheelies fine
post pics, is it the one in your avatar?Originally Posted by devilishtrendz
i wonder how the bike would handle with the wider rear tire for a sm set up
dude that gonna be my next mods! z 50 chrome wheels with street tires! looks like a little tank! do they sell white walls for the zees?
also would i need crf70 front end or a z50 front end? im thinking i would like the 70 front more but i dont wanna make the bike look huge.
This is a project I am currently working on. The wheels work fine as long as you have the spacers as stated previously. Hope you all enjoy.
at are you guys doing on the brake side, ive got some monkey wheels from a 2009 and brake hub is a far way in from the knob on the swingarm.. i did a quick measure of a Z50R wheel and it was exactly the same width.
would be nice to see more detailed photos either side of the hub.
20plus
Fifty Riders
Never mind guys... i did some more measuring and the Z50J rims go straight on as well, the distance between the brake hub and the sproket are the same on CRF rim vs Z50J ... I thought i was going to have to make spacers up either side but its just the sprocket side needs the spacer.
20plus
Fifty Riders
Randomly came across this in a google search and yeah I know I'm reviving it...
After making a ride with the NOLA Ruckus crew sunday and seeing all the fat tires, I'm itching to do one on my street legal CRF50. It appears from reading, I only need a Z50 wheel, hub, brake and a spacer... Right? Or does a CRF50 brake drum happen to fit on it? I'm also considering getting some knockoff wheels, hub and brake so I can get new stuff.
Any help, info or more pictures is appreciated!
