T-Bolt USA Tech Data section and PM member submissions - Page 4
This is a discussion on T-Bolt USA Tech Data section and PM member submissions within the T-Bolt USA forums, part of the PM Supporting Vendors category; Thanks to Panic Grip i can add more info directly to our online Tech Data Base again Way to go man !! Just added: Understanding ...
Page 4 of 4 FirstFirst ... 234
Results 46 to 53 of 53
Like Tree2Likes
Thread: T-Bolt USA Tech Data section and PM member submissions
  1. #46
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Way to go man !!
    Just added:
    Understanding Cam Gear Ratios - TBolt USA Tech Database!
    4 Stroke engine crankshaft/camshaft gear ratio is always 2:1, which means that for every two revolutions of the crankshaft the camshaft will rotate through one revolution.
    This is a 2:1 ratio and must always remain
    The top cam sprocket will have twice as many teeth as the crankshaft cam-chain sprocket.
    Typically, Honda 50 and 50-110cc Chinese engines and Lifan 140, have 28 tooth cam sprockets.
    Jailing and GPX and YX 140 engines have a 32 Tooth cam sprocket.
    When installing a performance camshaft you may replace the cam sprocket but only due to the bolt pattern.
    The new cam sprocket must have the same tooth count as the original sprocket.
    T Bolt USA - Let's go riding!
  2. #47
    is Double Truckin' the Tricky Two
    BaBy!
    XLr8r's Avatar
    Apr 2007
    Muddin'
    Here's another useful tidbit from the KLX110 Service Manual.
    I figured I'de save the Wiring Diagram as it's own file so it's easier to find.
    Her ya go:........ attatched below:......
    Attached Files Attached Files
    I'm probably a lot faster than you think you are.
  3. #48
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    BIG KLX TYPE Pit bike motor port TECH DATA
    YX150/160
    A type head - Honda intake & Honda EXH ports
    B type head - KLX intake & KLX EXH ports
    ZS155cc
    B type head - KLX intake & EXH ports
    C type head - KLX intake & Honda EXH ports
    Matified's Avatar
    Feb 2008
    USA
    To add just a little, The ZS heads have different cam and tappet covers, so when switching to a v2 or +R head you will need KLX style covers to finish it off.
  6. #50
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Quote Originally Posted by Matified View Post
  7. #51
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    We have been adding to the tech data over the years as we have more info to share
    here is a cool one from a great PM member
    LINK:
    Mahinsminis likes this.
  8. #52
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Panic Grip Designs is at it again
    DISPLACEMENT CALCULATOR (MM TO CC)
    LINK:
    TBolt USA - A Decade of Pit Bikes, Engines and Parts!
  9. #53
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Cool feedback !!
    neilson:
    I just wanted to say thanks for such a great TB 88cc kit install info. I got into a jam installing my race cam in my crf50 and your tech database got me through it. Just wanted to say your customer service is A++++ and I will send all my friends to Tboltusa
    Greenfz1 likes this.
2007 ssr 110 pit bike kickstart diagram
danos bike shop technical
how to check rings in a bore
how to replace yx150 valves
pit bike parts
pitsterpro140 com-wiring diagram
plug reading
tbolt tech data base
tboltusa review
ttr110 150cc
yx pitbike clutch diagram
z50 big bore engine
