#1
Sep 6, 2009
Hi , we have a new data base set up for online Tech Data , please review if you have time
TBolt USA, LLC Tech Database - Home
the current sections are some of the simple common and reoccurring questions and tech calls we get every day so this should help
we have more to come but it takes time
a few i would like to add:
how to install/ adjust a clutch cable (dont laugh)
oil filter / clutch maint
how to install a cam
how to adjust you chain
if any PM member would like to add anything we would be interested in your input
thanks
vince
See less
See more
#2
Sep 6, 2009
Re: Tech Data section and PM member submissions
Cool feature, I think it is great when companies like you and BBR take time to show and help the customer.
#3
Oct 11, 2009
thank you sir ,
PLEASE HELP WITH TECH DATA
im trying to find a few good pictures of the top of YX motors to represent the differences in honda port and KLX port china heads
THANKS !!
#4
Nov 7, 2009
T Bolt USA said:
thank you sir ,
THANKS !!
just submitted this head compairison data
TBolt USA, LLC Tech Database - YX 150/160 ,ZS 155 ,V2 & +R Head types
please check it out and see if it helps and makes sense
#5
Nov 7, 2009
are there 8mm exhaust studs on the KLX ported engine?...or is that just the V2 take/KLX heads
#6
Nov 7, 2009
well there have been on quite a few we have seen but if you have different info just let me know , this whole tech data section is an attempt to supply quick usefull info no just our customers but to the general public
#7
Nov 7, 2009
really cool you are taking time to do this.
#8
Nov 7, 2009
Thank's Vince.
#9
Nov 8, 2009
Most def thank you for doing this it will help me and my dad when were stuck on doing my motor. Props to you TBOLT
#10
Feb 21, 2010
hi
i just updated the tech area with is info on plug reading for proper jetting
a few guys are wanting to jet there carbs in and fine tune and they hear about plug reading but dont know how to read the plug so i hope this helps
#11
Feb 28, 2010
When trying to build an engine or source a Big Bore kit at times we need to know how "Tall" the cylinders is
just uploaded this to our tech data section
#12
Feb 28, 2010
Pitster Pro also not only has a fulltime techs during business hours, has a
techhelp@pitsterpro.com Q&A, but also provides tech sevices to its dealers like Tbolt USA.
#13
Feb 28, 2010
ok now this post is just GAY
#14
Mar 7, 2010
Matt did this one, thanks !!
#15
Mar 9, 2010
Button should be in or out when starting?
#16
Mar 11, 2010
push in the button , it pops out when the motor starts
#17
Mar 11, 2010
Here is some Quick info on Chain sizing
Check you size before ordering
Most Pit Bike take 420 chains:
CRF50
XR50
KLX110
SSR
Some take 428
EXTREME
SOME Pitster
SOME OGM
#19
Apr 24, 2010
For most current updates please access our Tech data from our main page
Just added some general Pit bike engine sizing info with diagrams
Mostly for the guys who are doing projects
#20
Jun 16, 2010
hi
we have some simple text instructions online in our tech data section about how to adjust your cam timing and your valves
but we would like to add a few pictures
if anyone has a clear picture or has seen it online please let me know
#22
Jun 19, 2010
Very good info Vince! Nice job
#23
Jun 19, 2010
The roller diameters are different for 420 and 428 chain. The 420 is 7.7mm .303 inches and 428 is 8.5mm .335 inches. The rear sprocket is a BAD fit.
Check the DID specs here:
Specs
Don
#24
Jun 19, 2010
Specs
Don
thanks man for the additional info
now guys can tell a 428 from a 420 chain by 2 methods/measures
#25
Jun 27, 2010
here is a little info on KLX & YX150/160 & ZS155/HO160 covers
