Purchased this for my ATC 70 bolted right in ordered the VM26 carb and intake. Talk about a fast ride, great motor and perfect power plant to drive me through the dunes of Glamis. Shipping was good packaging was good support was great, good advice and knowledgeable assistance when needed...
Note:
When upgrading your Honda XR50/70 ,CRF50/70 to this engine you
may want to use order aftermarket footpeg mounts and tank spacers.
Also we suggest using an aftermarket exhaust to obtain maximum performance.
All of these items are availble at TBoltUSA.com Engine Specs
Bore:56mm
Stroke:57mm
Displacment:140.4cc
Big Valve 27mm/23mm head
Gears:4 speed ,bottom neutral 4 up shifting
Carb:22mm mikuni
Ignition:Standard Flywheel ignition Kit Includes
Carb
Kicker starter
Shifter
Electrical components Not Included
Skid plates
Exhauste
Air filter
Clutch Cable
Throttle Cable
Available Options:
[h=1]Piranha 90cc Semi-Auto Engine
w/ carb & electric
[WHS-1784-KIT][/h]
Piranha 90cc Semi-Auto Engine w/ carb & electric
See picture for parts included , only as pictured.
Great Replacment engine or for builds & Projects.
Includes:
Engine
Carb
Intake
CDI
Coil
Harness
Kicker
Shifter
Displacement
86cc
Engine Type
Air Cooled, Single-Cylinder, 2-valve, 4-stroke
Bore/Stroke
47mmx49.5mm
Final Drive
Chain
Fuel Delivery
22mm carb
Fuel
Unleaded / 93 Octaine
Reccomended Engine Oil
10W-40 Petroleum Based (Nonsynthetic)
Ignition
Kick Start
Yes
Electric Start
no
CDI
yes
Auxillary Output
Yes
Transmission
Transmission
4-Speed Semi Auto
Shift-Pattern
Four-speed Transmission: N-1-2-3-4 (Four Up)
Clutch
Semi auto (no hand clutch)
Note:
Type 4-Stroke single-cylinder OHC air cooledPiranha 90cc
Hi Please make me a complet COMPLET kit, with Yx140, the best exhaust you have with the best carb you have, to fit my 12v ligthening kit i want run my lightening without batteries so can you modifie the engine to have a stator to make this happen?
Can you update the engine with a better cam? if yes please add goodies to the engine to be at it best. I want a oil cooler too.
