yx150 clutch basket teeth brakeing
This is a discussion on yx150 clutch basket teeth brakeing within the T-Bolt USA forums, part of the PM Supporting Vendors category; i have a 2007 pitster pro with a yx150 bored to a 160 and i was riding it yesterday and it was making alot of ...
Results 1 to 7 of 7
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    i have a 2007 pitster pro with a yx150 bored to a 160 and i was riding it yesterday and it was making alot of noise so i took it apart and i found four teeth laying in the bottom of the case and they came off the clutch basket so i want to no what causes that to happen. thank you
    storminnorman07's Avatar
    Nov 2005
    new castle, pa
    Quote Originally Posted by bfaith View Post
    my money would be it failed cause of the horrible clutch wobble they have.
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    No I talked to the last owner and he said he raced it and he did race starts all the time
    50rider340's Avatar
    Mar 2004
    CT
    Regardless of the last owner these engines have "bad clutch wobble." If he raced it too, chances are its been hammered on. As for a cause? I'd think of it like a snow ball rolling down a hill, starts off small then gets bigger. So the teeth on the basket one failed then the rest went with it. The tooth failure could be a number of things, poor casting, metal fatigue, etc. I'd look at everything else in there while its apart, chances are some other things got ate up too.
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    I fixed the problem and got a new clutch basket and I ordered a new clutch hub because it broke after the clutch basket but now it makes like a grinding howling noise like something is grinding or vibrating do u have any ideas thanks a bunch
    is Eat - Sleep - Work - Live -
    PIT BIKE !
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Lets get it apart and get some pics
    T Bolt USA - Let's go riding!
    Online Store - Tech Database - Facebook - TheCRKid@TBoltUSA.com - (704) T-BOLT-US - Skype: TBoltUSA
  7. #7
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    i took it apart and the problem was the bolts on the clutch basket were scretching and they were about to break so i put some new ones in and put allen bolts in the clutch and oil slinger and when i put it back together there was a really bad vibrating sound so i took the clutch cover off and there was nothing rong so i put it back together and i started it and the problem was that the skid plate was vibrating like crazy and i never noticed it so it is working good. but it seems like there is a wissling sound in the light side of the motor is that supost to be there? it wasnt there before. thanks for all the help to really needed it.
  1. yx150 clutch basket teeth breakedge
    By bfaith in forum Chinese/Import Minis - General Discussion
    Last Post: 04-15-2012, 06:36 PM
  2. Yx150 Clutch Basket Destroyed
    By calcant10 in forum Chinese/Import Minis - General Discussion
    Last Post: 09-03-2011, 11:43 AM
  3. Ate 3 clutch basket teeth????
    By bigbadgixxer in forum KLX110, DRZ110, TTR90
    Last Post: 06-20-2010, 08:40 AM
  4. WTB yx150/160 clutch basket
    By azextreme in forum Vendor Area - Wanted
    Last Post: 06-21-2008, 12:04 PM
  5. Lifan or GPX Basket...how many teeth?
    By fatcaaat in forum Chinese/Import Minis - General Discussion
    Last Post: 02-09-2008, 05:42 PM
basket for teeth
clutch basket noise
pit bike clutch basket
pit bike yx 150 clutch cover
pitster pro 150 clutch basket
pitster pro clutch basket
pitster pro ho 160 clutch basket
tools to take a pitsterpro clutch apart
yx 150 clutch case
yx 150 clutch cover
yx150 clutch is slipping
yx150 keeps breaking cluth basket teeth
