klx 110L Transmission prob
This is a discussion on klx 110L Transmission prob within the T-Bolt USA forums, part of the PM Supporting Vendors category; 2013 L. Trans is acting up, occasionally finds a false neutral & grinds between 2 & 3rd & occasionally goes from 3rd to 1st on ...
Results 1 to 6 of 6
    is Barnyard racing
    gruvey12's Avatar
    Apr 2008
    Columbus Ohio
    2013 L. Trans is acting up, occasionally finds a false neutral & grinds between 2 & 3rd & occasionally goes from 3rd to 1st on a downshift. Planning on splitting cases, what parts are needed? Would like to switch to neutral at the bottom & 4 up if possible like my full mod 2008 is.
    I'm looking to get all the parts now ahead of time and then give to engine builder.
    Obviously it's stroker crank time as well while it's open.
    Do you have the parts available or point me in the right direction?
    donmx14's Avatar
    Jan 2009
    latrobe, pa
    We have one that will shift from 3rd to 1st or 3rd to neutral sometimes. Normally only happens when the clutch is pulled in coming into a turn. If you just down shift with out clutch is fine. Our other 110l tranny is flawless I will be swapping out the 110l drum a star for tak 1d3up drum
    nicko451's Avatar
    Feb 2010
    Mine does it too with or without using the clutch
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    Quote Originally Posted by nicko451 View Post
    There is really no way of knowing what parts you need until we do a tear down. You could get the 4speed drum a head of time though
    Ride on the edge
    is Barnyard racing
    gruvey12's Avatar
    Apr 2008
    Columbus Ohio
    On it. Sending to you soon.
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    Ok cool
    Ride on the edge
  1. 110L Clutch/Transmission Upgrades
    By CGuerra54 in forum KLX110, DRZ110, TTR90
    Last Post: 07-07-2014, 10:26 PM
  2. Replies: 15
    Last Post: 10-13-2011, 12:47 AM
  3. any one else have this prob???
    By slapaho16 in forum CRF50
    Last Post: 01-19-2007, 02:37 AM
  4. klx 110 prob.
    By yamaha_racer in forum KLX110, DRZ110, TTR90
    Last Post: 02-16-2006, 12:19 PM
  5. klx 110 prob.
    Last Post: 02-12-2006, 08:19 PM
