Are there any bolt on swingarms for an xr75 that are wider than the stock swingarm? Has anyone ever used an aftermarket z50 or monkeybike swingarm on an xr75? Looking to be able to use nsr50 wheels and any help is appreciated!
This is a discussion on xr75 Swingarm Options within the Vintage Honda XR75 and JDM Vertical Motors forums, part of the General Talk category; Are there any bolt on swingarms for an xr75 that are wider than the stock swingarm? Has anyone ever used an aftermarket z50 or monkeybike ...
Suzuki DS 80 swingarm can be made to work. You have to make shock mounts and cut off the bracket for the original shock. Cool looking swingarm, looks like alum box but its steel. I can try to take some picks. How wide do you need? I can try to measure. Its about the same length. Im using yamaha ysr50 rims 12 inch. on a Z50 frame. I have a xr75 frame im not using and I was compairing them.
