New Member, New Bike, Lots of parts on their way!
This is a discussion on New Member, New Bike, Lots of parts on their way! within the Vintage Honda XR75 and JDM Vertical Motors forums, part of the General Talk category; Hello everyone. My name is Kyle and I was just given a 1976 Honda XR75. Engine case says XR75E (if that matter) Well the bike ...
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
    Rimfirekyle's Avatar
    Jun 2012
    SW Missouri
    Hello everyone. My name is Kyle and I was just given a 1976 Honda XR75. Engine case says XR75E (if that matter) Well the bike ran....very....very poorly. It had no power and smoked. Started disassembling bike and got to the motor. Found a ring busted,a tone of carbon, and one twig on top of the piston. I wanted to make this bike nice and if i was going to tear it down to fix it, I was going to do it right. So, I ordered a ton of parts which will be here monday or tuesday and I am excited.
    I started tearing down the engine and got the top end off no problem. But, how do I get the flywheel off?
    I love the site and there is a lot of good info here, I hope to be here a while.
    is almost done with the XR75...
    vintagemx's Avatar
    Oct 2011
    Seattle
    Nice project. I bought a "running" early XR75 (cobbed together from '73 - '76 parts) for my oldest boy. Previous owner claimed he rebuilt the engine, but that it had "old gas". It didn't take me long to realize his mechanical skills are seriously lacking. Old gas wasn't the problem, too much gas was. Ended up rebuilding the carburetor, which got the bike running, but the spark was very weak and would still foul plugs. Changed both the stator and ignition coils and now it has good spark. The engine burns oil, so the top end needs to come down and the bottom end has a leak. That said my son still rides the bike and has raced it a couple times. I'll probably end up rebuilding it back to stock someday.
    Stubo's Avatar
    Apr 2012
    Fairfax VA
    You will need a flywheel puller, you will also need a special tool to remove what Honda calls the oil filter if you paln on splitting the cases or doing any type of clutch work,
    I made the tool but you might be able to still buy it. I will get a photo for you as soon as i can
    Jun 2012
    SW Missouri
    thank you so much..... i ordered the flywheel puller..... apic of the other tool will be great!
    is just truckin' along...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    A pic of the tool is HERE, and the nut you use it on is part #16, shown HERE.
    - dirtbkr188 -
    Jun 2012
    SW Missouri
    ordered the tool.... thank you so much.... That site has all the blown up diagrams which is awesome. Is there a site out there that has them in a printer friendly format?
  7. #7
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Yes, go back to that site, click on Large Image right under the diagram, when it opens, right-click on it, click on Print Picture.
    - dirtbkr188 -
  8. #8
    Jun 2012
    SW Missouri
    Ok well, I have good news and bad news.......
    All my parts are here and they look awesome....
    Tank, frame, swingarm, and various pieces are blasted and headed to paint.
    bad news. Threads on flywheel are goobered and I cant get it off.... Any Ideas?
  9. #9
    vintagemx's Avatar
    Oct 2011
    Seattle
    You do realize the threads in the flywheel (for the puller) are left-hand threads.
    Lefty-tighty, righty-loosey
  10. #10
    Jun 2012
    SW Missouri
    after about 5 minutes I did....... And I thought " oh yeah, now ill get it" And then realized, nope they really are screwed up. Apparently someone has had this apart before. You can see where they used a crow bar/screwdrive to pry the flywheel off.... ouch
  11. #11
    vintagemx's Avatar
    Oct 2011
    Seattle
    Try cleaning the threads with WD40 and a wire brush first. If that doesn't work, plan B... Squirt WD40 around where the flywheel fits onto the crank taper. Heat the flywheel with a propane torch around the crank taper then CAREFULLY pry on the back of the flywheel.
  12. #12
    Jun 2012
    SW Missouri
    Ok, I will try the WD-40 and brush. I have some plastic coated bars for gunsmithing that might work for prying it off of there.
  13. #13
    vintagemx's Avatar
    Oct 2011
    Seattle
    Can you get a close-up photo of the threads. Usually just the first thread or two get messed up. Years ago I borrowed a special flywheel thread chaser from a Honda mechanic.
  14. #14
    is XR75 & YZ80 NUT!
    hobbeekid's Avatar
    Oct 2010
    Manteca Ca.
    Be careful with the threads on the flywheel they're really fine ind you can easily crossthread when trying to install puller. I also use alittle grease on the inside of puller to keep from galling up or spreading out the end of the crankshaft end also...
  15. #15
    vintagemx's Avatar
    Oct 2011
    Seattle
    Quote Originally Posted by hobbeekid
    ... use alittle grease on the inside of puller to keep from galling up or spreading out the end of the crankshaft end also...
    A dab of anti-seize or Texaco "ThreadTex" works even better.
  16. #16
    Jun 2012
    SW Missouri
    Well i took to "Off road connection" A local repair shop. He is going to try. Might pick it up tonight if he gets it off.... I want to finish rebuilding the motor this weekend if I can.
  17. #17
    Jun 2012
    SW Missouri
    Ok, so it has been a while since I posted so I thought I would update. Picking up frame, fenders, and tank from my paint guy this evening. I will post picks this evening. Im pumped! Ive been busy and still have not got the flywheel off of it. The guy at the repair shop couldnt get a puller to thread into it .I got the puller to thread in about 2 threads and am going to try to pull it off tonight. I would love to have a thread chaser and mentioned above but cannot find one locally.
    PICS TO FOLLOW THIS EVENING
  18. #18
    Jun 2012
    SW Missouri
    Also I want to replace my fork seals tonight..... I couldnt find a post explaining how...... any one know of a page describing this process???
  19. #19
    vintagemx's Avatar
    Oct 2011
    Seattle
    I'd highly recommend getting a Honda XR75 service manual. Accept no substitutes. Re-mx sells copies, but the photos aren't very good. Look for an original on Amazon or flea-bay.
    Try talking to a Honda mechanic about chasing the threads. The one I borrowed looked like it had been made from a flywheel puller, with 4 grooves cut vertically the length of the threads.
  20. #20
    bluebanshee's Avatar
    Jan 2007
    I've never used the thread in pullers and have never had one that I couldn't get off. A regular puller, some heat and some light taps have always popped them off for me.
  1. Lots of crf50 parts 3 bike partout
    By zmurph91 in forum CRF50/CRF70 Parts For Sale
    Last Post: 10-30-2010, 04:35 PM
  2. Replies: 59
    Last Post: 07-21-2008, 09:25 PM
  3. Parting out Bike - Lots of Parts
    By MrMoose in forum CRF50/CRF70 Parts For Sale
    Last Post: 07-26-2007, 09:49 PM
  4. Replies: 42
    Last Post: 01-03-2007, 09:24 AM
  5. lots and lots and lots of stock parts for a 110
    By sobesuzuki99 in forum CRF50/CRF70 Parts For Sale
    Last Post: 07-16-2004, 02:49 PM
1974 xr75 flywheel puller
bultaco oil pump
honda xl 75 service manual
honda xl75 flywheel removal
honda xr75 flywheel puller
how to change oil screen honda xr75
how to remove a 1976 honda flywheel
how to remove honda xr75 oil pump
is the honda xr75 oil pump rotor nut left-handed threads?
what kind of oil does the 1974 honda xr 75 owners manual
xr75 parts
