My 1980 Honda XR 80 rebuild - Page 2
This is a discussion on My 1980 Honda XR 80 rebuild within the Vintage Honda XR75 and JDM Vertical Motors forums, part of the General Talk category; Swing arm and front motor mounts primed and painted....
Page 2 of 11 FirstFirst 1234 ... LastLast
Results 16 to 30 of 163
  1. #16
    Crappie Master's Avatar
    Mar 2014
  2. #17
    Mar 2014
    Triple clamp sanded, cleaned and painted
    Now kick stand, peg mount bracket and rear wheel support
  3. #18
    flower's Avatar
    Jun 2008
    MO
    There may not be "market value" but there is definitely vintage and worthwhile value in doing what you are doing. I love the older bikes with the flatter frame design and older two shock suspension. But, that is cause old guys like old stuff and like to see it revitalized for younger folks enjoyment and historical value.- Bobby E.
    Live to ride or ride to live that is the question.
    Mar 2014
    I plan to sell the bike when i'm done restoring it. I'm just going to try to sell it for what i got in it. I think i can finish it with about $800 in it. If everything goes well this project I'm thinking the next bike will be like a XR 75, Z50 or a early CRF( 70-125 hp)
  6. #20
    Mar 2014
    Swing arm and triple clamp put back on bike. Ordered new grommets for bike yesterday. I guess next thing is to do is polish up forks. I got a inner fender off eBay. It came yesterday. Haven't taken it out of box yet, but it looked to be in a lot better shaper than the one that was on bike. It was badly dis colored and melted.
  7. #21
    Mahinsminis's Avatar
    Jul 2013
    Idaho
    Looking good.
  8. #22
    Mar 2014
    Now time to work on the wheels and air cleaner box. I ordered new grommets and acorn shock nuts. Should be here tomorrow
  9. #23
    Mar 2014
ID:	153292 Click image for larger version.
    Forks are on and new grommets installed
  10. #24
    Mar 2014
    Well i have two problems! I can not get the spokes to clean up an shine. There is some rust on the rims, but not so bad to replace them. I guess i will take wheel apart and paint hubs black and replace the spokes. I might as wheel get the correct rear hub. The one i have is from a CR 80. The sprocket bolts were rubbing against the inside of the swing arm. I'm also preparing air cleaner box for some primer and black paint.
  11. #25
    mxnut23's Avatar
    Apr 2011
    At this rate you'll need another project before winter is over
  12. #26
    is thinking of upgrading the '74
    XR75
    vintagemx's Avatar
    Oct 2011
    Seattle
    If you're interested, I will sell you the complete wheels off the bike pictured below. The wheels are originally off a '74 XR75, but they will fit all years of XR75's and XR80's up through '84. I spared no cost on them. The hubs and rims were powder-coated black then relaced with new spokes. I also installed new bearings and new tires that have less than a dozen races in dirt only. I upgraded the bike with XR100 wheels last summer and don't really have a use for these wheels now. If you're interested, send me a PM.
  13. #27
    Mar 2014
ID:	153480 Ready for paint Click image for larger version.
ID:	153481 Primed Click image for larger version.
ID:	153482 Painted.....Now back to the wheels. Decided replacing spokes on wheels would be too expensive. Trying not to put too much money in bike. At his time i'm going to remove paint from the hubs and repaint black. Clean rims best i can. There in pretty good shape. I'm going to try drilling on rear sprocket bolts. Then i'll get a Cr 80 rear sprocket. I'll then get some allen head type bolts that have a concaved head. So the head won't stick out to much. And rub frame. If this fails i'll buy a used XR 75-80 rear hub.
  14. #28
    XR75
    vintagemx's Avatar
    Oct 2011
    Seattle
    I got a spoke kit off e-bay for $50.
  15. #29
    Mar 2014
    I ruined rear hub trying to remove sprocket bolts. Dang it!!! Now to find the correct wheel for the bike. A XR 80 rear wheel. Found one on ebay for $68 w/shipping.
  16. #30
    mxnut23's Avatar
    Apr 2011
    What happened?
  1. 1980 Honda XR 80 wheels
    By Crappie Master in forum Vintage Honda XR75 and JDM Vertical Motors
    Last Post: 11-15-2014, 02:29 PM
  2. Who do I get to rebuild a 1980 z50r motor?
    By HDminiZ in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 12-06-2013, 06:49 PM
  3. 1980-1987 Honda z50
    By troyweaver in forum Bikes and Parts Wanted - All Makes
    Last Post: 03-12-2013, 04:44 PM
  4. 1980 ct70 shock rebuild help
    By soundwav in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 02-02-2010, 03:09 AM
  5. 1980 honda ct 70
    By mx470 in forum Complete Bikes For Sale - All makes and models
    Last Post: 08-26-2008, 12:16 PM
1980 honda xr80 parting out
1980 honda xr80 parts for sale
1980 xr80 tank
does a xr 80 rear wheel fit a cr 80
fuel lines from gas tank to carburetor on honda xr80
honda xr frame paint
honda xr75 keihin carb jet size
honda xr80 carb should i rebuild or buy new?
honda xr80 installing carb slide
honda xr80 misses in the high rev range
main jet size 1980 honda xr 80
rebuilding87xr80
