My 1980 Honda XR 80 rebuild - Page 3
This is a discussion on My 1980 Honda XR 80 rebuild within the Vintage Honda XR75 and JDM Vertical Motors forums, part of the General Talk category; I got lazy i guess. I drilled a small hole about 3/4" into bolt. Then drilled a 3/8" hole. The 3/8" drill bit got off ...
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 31 to 45 of 163
  1. #31
    Crappie Master's Avatar
    Mar 2014
    I got lazy i guess. I drilled a small hole about 3/4" into bolt. Then drilled a 3/8" hole. The 3/8" drill bit got off course. I should have used a bigger pilot drill bit and i should drilled pilot hole all the way thru bolt.
  2. #32
    Mar 2014
ID:	153661 With steel wool and some rust dissolving gel i got front rim looking pretty good. I plan to leave he hubs aluminum. No paint. I found a back wheel on ebay. It was about $60. I was hoping someone on here had a little nicer for about same money. I have about a half a dozen things on order. New gas tank fuel petcock, gas tank cap rubber washer, chrome washer to go under steering column nut and few other small parts.
  3. #33
    Mar 2014
ID:	153700 Brake plates have had paint removed and are ready for paint. Gas tank is next thing to have paint removed!! Click image for larger version.
ID:	153701 also: vintagemx has a rear wheel that will work for me. He is to send me pics monday.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    I'm quite surprised you didn't try to remove the sprocket studs from the CR wheel with a little heat and a pair of vise grips, rather than trying to drill them out.
    - dirtbkr188 -
  6. #35
    Mar 2014
    Well if i could start again i'd done that. I didn't know you could heat up aluminum. I thought it would melt. Even if i would have got CR hub studs out i would have had a tough time trying to rig it so bolt head are nuts were almost flush with sprocket. The XR sprockets studs are weld to them so there flush. Really isnt enough room for nuts on outside of sprocket, but you probable knew that
  7. #36
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You could have countersunk the bolt holes in the sprocket, and used M10 countersunk allen sprocket bolts.
    - dirtbkr188 -
  8. #37
    Mar 2014
    That was my plan....
  9. #38
    Mar 2014
    Primed and painted!
  10. #39
    Mar 2014
ID:	153792 Front wheel is all done!!! Now i need to order new cables. I'm bidding on used XR 75 handle bars for it now. I look to get bars for $21. I'll have to repaint them, but still alot cheaper than new ones for a $100
  11. #40
    Mar 2014
    I ended up being high bidder on XR 75 handle bars on Ebay, so there on there way. They looked pretty good but i still plan to repaint them. I did a buy it now on Ebay for a 1979 XR 75 rear wheel for $68. Pretty good shape. I'll strip off it's paint and remove rust from rim an polish it up. I also bought a new IRC 3.60-14 intermediate rear tire off ebay for $55.
  12. #41
    Mar 2014
    Yesterday i ordered a throttle,brake and clutch cables. Also ordered grips and twist throttle. I figured since i'll have handle bars soon, I just as well get the the stuff that goes on the bars and have it done. I have been working on removing paint from gas tank.
  13. #42
    theraymondguy's Avatar
    May 2010
    Niagara, ON
    Quote Originally Posted by Crappie Master View Post
    It's a little late, but CR bend bars are a good bit narrower than the XR75/80 bars which tend to unbelievably wide. Also CR85 clutch lever offers a bit easier clutch pull (not so bad on the XR80R, definite must on an XR100R).
    Something I'm not too late for, an All Balls steering stem taper bearing kit (same as Z50 kit). Eliminates chasing the loose balls all over your shop, trying to assemble them onto the races without loosing most/many of them, not to mention improved front end feel.
  14. #43
    Mar 2014
    I wanted bar to look like original. CR's would have worked, just didnt want pro taper looking bars. Steering column done. Got 22 new bearing. Went together well. So your saying the bike is known for having a stiff clutch lever. It was a little hard to pull clutch in before i started taking bike apart
  15. #44
    May 2010
    Niagara, ON
    Sure. Why not swap the front wheel for a CT90/110 hoop? The tire selection for 16" blows. - Sorry, just noted you've got the front wheel and tire assembled as well.
  16. #45
    Mar 2014
    I got to keep cost down as much as i can. If i did new triple clamps and forks i think i would do a CR 100. Cant remember exactly what year. I think mid 80's
  1. 1980 Honda XR 80 wheels
    By Crappie Master in forum Vintage Honda XR75 and JDM Vertical Motors
    Last Post: 11-15-2014, 01:29 PM
  2. Who do I get to rebuild a 1980 z50r motor?
    By HDminiZ in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 12-06-2013, 05:49 PM
  3. 1980-1987 Honda z50
    By troyweaver in forum Bikes and Parts Wanted - All Makes
    Last Post: 03-12-2013, 03:44 PM
  4. 1980 ct70 shock rebuild help
    By soundwav in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 02-02-2010, 02:09 AM
  5. 1980 honda ct 70
    By mx470 in forum Complete Bikes For Sale - All makes and models
    Last Post: 08-26-2008, 11:16 AM
1980 honda xr80 parting out
1980 honda xr80 parts for sale
1980 xr80 tank
does a xr 80 rear wheel fit a cr 80
fuel lines from gas tank to carburetor on honda xr80
honda xr frame paint
honda xr75 keihin carb jet size
honda xr80 carb should i rebuild or buy new?
honda xr80 installing carb slide
honda xr80 misses in the high rev range
main jet size 1980 honda xr 80
rebuilding87xr80
