81 XR80 Ignition Questions
This is a discussion on 81 XR80 Ignition Questions within the Vintage Honda XR75 and JDM Vertical Motors forums, part of the General Talk category; Recently bought this XR80 to use as a pitbike and putt around on. In fair condition overall. It runs but not well at all. I ...
Results 1 to 5 of 5
    UTBMXCruiser's Avatar
    Jun 2016
    It runs but not well at all. I set the timing as best as I can with a digital Ohm meter but I don't think things are right with the points. This Ohm meter I have also has a built in buzz box.
    In order to get any kind of fluctuation in the meter when adjusting the timing I have the meter on 20K. This the only setting I get any kind of indication that the points are opening and closing and even that is really sketchy. On that buzz box setting, the buzzer stays on all the time points open or closed. I'm wondering if I have a short in the single stator wire or the points are grounding out. Shouldn't the buzz turn off when the points open? I know for a fact the points are opening and closing.
    I've never had a bike with ignition points. I understand how it works but I have no experience troubleshooting a points type ignition.
    Also, the condenser is mounted, actually riveted to the coil. Should I change that condenser? All the ones I see for sale are not this same type and I would have to rig something up to replace.
    Somebody help me out!!! I don't see much traffic on this site and I really hope somebody sees this!!!
    Thanks,
    Dan
    piranito's Avatar
    Jan 2014
    Germany
    Buzz should not turn off but must differ in sound when points open.
    Set points to recommended point gap and check with a timing light. All the other methods are bulls**t.
ID:	178937Click image for larger version.
ID:	178945Click image for larger version.
    Should (when points are allright and all the setting is done) the points start firing, you have to replace the condenser with something matching. F.e.: Condenser Centre for 1980 Honda XR 80 A | eBay
    Also check float level height - 0.85in - and pilot jet. There must be light when looking all through the length of the jet.
    Valve tappet clearence is important too. Set it to 0.002in.
    Alex
    is XR75 & YZ80 NUT!
    hobbeekid's Avatar
    Oct 2010
    Manteca Ca.
    I've always gotten the best results using a test lamp method, the lamp should be bright as you turn the flywheel until the f mark lines up with the index mark showing the points are opening. the bulb should go dim at that point showing a break in the circuit & correct ignition timing.Adjust points until bulb goes dim at that mark. My experience with that method has given the bike a showroom idle...
    piranito's Avatar
    Jan 2014
    Germany
    Quote Originally Posted by UTBMXCruiser View Post
    Did YOU see?
    theraymondguy's Avatar
    May 2010
    Niagara, ON
    The ignition advance springs may be elongated/stretched as well in the mechanical advance as well.
    Ignition components on these bikes are all NLA, I made due with a 6V Z50R coil and mounted the condenser to the coil.
  1. A Few 81' Xr80 Questions.
    By kxking in forum Vintage Honda XR75 and JDM Vertical Motors
    Last Post: 03-28-2011, 11:57 AM
  2. xr80/100 valve questions
    By FiveStarSky in forum Bigger Minis Forum
    Last Post: 12-10-2009, 10:12 PM
  3. xr80 carb and upgrade questions
    By IriDeUrmOm in forum Bigger Minis Forum
    Last Post: 09-16-2009, 01:26 AM
  4. Kitaco, INNER ROTOR IGNITION questions!
    By StuntinFiddy in forum KLX110, DRZ110, TTR90
    Last Post: 05-11-2009, 05:17 PM
  5. 2003 XR80 ignition switch
    By 2bamp in forum Bigger Minis Forum
    Last Post: 04-19-2009, 07:19 PM
