Hi, Im building my unicorn xr75 w xr200r
This is a discussion on Hi, Im building my unicorn xr75 w xr200r within the Vintage Honda XR75 and JDM Vertical Motors forums, part of the General Talk category; Well , theres minis and theres minis .I always wanted something with enough power but reliable ,and able to hop on and go. I like ...
Results 1 to 10 of 10
Like Tree5Likes
  • 1 Post By Mr_Dunev
  • 1 Post By demidestructo
Thread: Hi, Im building my unicorn xr75 w xr200r
    demidestructo's Avatar
    Nov 2015
    I like retro , and the dual shock bikes I have always thought looked cool.
    I know the three wheelers in the 80s were very reliable, and the dirtbike versions had six speed trans.
    Well , i bought a three wheeler head which is about the same except has more fins to aid cooling. I bought a xr200r motor off a guy who thought oil was a million dollars. The cam lost oil and went to war with the head. I plan on going through it all and replacing everything. I want a new motor. I bought a 185 camshaft but I needed a good core for web. I want to build this motor to really move that xr75.
    Im thinking about a 230 crank, and maybe a 67mm piston. So 67mm bore x 66.5 mm stroke with web cam and headwork. I dont see why i cant use a tb 67mm piston in it .I m going to have the crankshaft trued and balanced as much as possible.
    The chassis i found from a buddy thats helping me out with the motor. He had cut the frame out to fit a 250cc off a rebel ! He didn't want to wire it for electric start, he was looking for a xr200r like i had.
    I cleaning the motor up now, pictures to follow.
    Sent from my SM-G900P using Tapatalk
    Mr_Dunev's Avatar
    Jul 2016
    Los Angeles
    Sounds interesting. How much work does it take to make the 200 motor fit in a 75 frame?
    demidestructo likes this.
    Nov 2015
    The xr200r motor has wider mounts than the xr75 . So im going to build a mount then weld it to the frame.
    Im using some gpx forks with a 17 cr80 disc wheel
    motodevo likes this.
    Nov 2015
    Quote Originally Posted by Mr_Dunev View Post
    I have trimmed some metal away to follow the contour of the motor. I need to build wider mounts with spacers . Theres really not much that needs to be changed. Im going to build a cradle / skid plate for the bottom.
    Nov 2015
    Im using a 1979 kx80 rear swingarm with the shocks with reservoir. I want to do something different with the fuel tank, like mount it behind the motor, inside the frame .That way it will move the weight lower and to show off the backbone of the frame . Something different from all the rest.
    Nov 2015
    Well i got a cr80 front 17 inch wheel .
    Tried mounting a stock tank but Im using a z50 tank
    I also chose a different swingarm, and some new handlebars.
    ds1506's Avatar
    Mar 2015
    Quote Originally Posted by demidestructo View Post
    How much work went into doing this? I'd like to update my front end to something a bit beefier if I can.
    motodevo's Avatar
    Feb 2011
    Australia
    Keep the pics coming, top work, should be a killer ride when done
  10. #9
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    HI there...YOu should look at my thread of CL125 where I put a CRF230 engine in a CL125 frame...which is just a little bigger frame than you have. I have also obtained a complete xr200 engine core and am currently rebuilding that engine for a future project that is a lot like yours.
    If you are interested, I do have a CRF230 crank here...the connecting rod is still in tolerance.
  11. #10
    Nov 2015
    Its easy , just get a taper bearing kit to remove the gap . I just put it through the head of the frame washer on bottom .
  1. Lifan 150cc engine now a unicorn?
    By Rangerscott in forum Chinese/Import Minis - General Discussion
    Last Post: 06-19-2016, 10:35 PM
  2. 1995 xr200r york pa
    By dr-z in forum Complete Bikes For Sale - All makes and models
    Last Post: 10-07-2013, 09:34 PM
  3. xr200r copy
    By a pearson in forum Bigger Minis Forum
    Last Post: 03-23-2012, 07:09 AM
  4. Replies: 5
    Last Post: 10-11-2008, 03:29 AM
  5. 2001 Honda XR200R for sale
    By GrandaddyPurp27 in forum Complete Bikes For Sale - All makes and models
    Last Post: 12-17-2007, 07:33 PM
