Motor swap XR75 - HTH
This is a discussion on Motor swap XR75 - HTH within the Vintage Honda XR75 and JDM Vertical Motors forums, part of the General Talk category; Wanted to post an engine swap that went well. I swapped a XR75E with a HE01E (maybe 1981-83), bolted right in and ignition was the ...
Results 1 to 9 of 9
    bbuevo's Avatar
    Nov 2008
    Florida
    Wanted to post an engine swap that went well. I swapped a XR75E with a HE01E (maybe 1981-83), bolted right in and ignition was the same. Use the 1977 coil, since its a 77 frame with a 1974 motor (I believe that is what the XR75E designates). This thing was all over the place from a parts perspective. However, it would be hard to find a better play bike and something so easy to ride, bling factor=0, she's not pretty.
    Issues:
    1. rust in tank - used muriatic acid to remove, repeated flushing
    2. replaced points/condenser with new which was ordered for the 75E motor (must be the same)
    3. cleaned carb, what a mess
    As for the 75E, I was thinking about rebuilding it as a project. Is there a one stop shop out there that can help with parts? I would be interested in making a super mini out of that one. Just not sure about where to get the goodies.
    The PM website has been really helpful and i appreciate everyone posting their 'how to's', came in handy.
    AHRMA361's Avatar
    Dec 2005
    back in O-H-I-O
    What is the complete serial number on the XR75 engine? The HE01 engine is an XR80 engine.
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    I think a honda cb125 or even a xr200 fits right in there.
    is Took Portland's job. I may be
    getting demoted again...
    Jarret53's Avatar
    Aug 2009
    Massachusetts
    Cb125 may but I pretty sure the XR200 is way to big to just bolt in. (everything is possible with fabrication)
    ryder2726's Avatar
    Aug 2008
    Here's my 1978 XR75 with a HE03E [xr100 engine 5 speed trans, est.1985?]Click image for larger version.
    bbuevo's Avatar
    Nov 2008
    Florida
    Here are the numbers from the motors:
    19XX:
    XR-75E 1217345
    19XX:
    HE10E-55090953
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Quote Originally Posted by bbuevo View Post
    here are the numbers from the motors:
    19xx:
    Xr-75e 1217345
    19xx:
    He10e-55090953
    1975:
    Xr-75e 1217345
    1984:
    He10e-55090953
    - dirtbkr188 -
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    IF i had an XR75 i would run an XR100 motor in it with a TB 120cc kit
    that way you can still put the OEM motor right back in
    T Bolt USA - Let's go riding!
  10. #9
    bbuevo's Avatar
    Nov 2008
    Florida
    Quote Originally Posted by T Bolt USA View Post
    What would be the best approach for the 1975 motor. I want to rebuild it, but while i am at it maybe bore/stroke if that is still an option for that year motor. Could someone tell me if there is a "one stop shop" for those accessories and machine work?
  1. Bought a 1977 xr75 missing flywheel and stator , will an xr80 swap work ??
    By BUSAMAN in forum Vintage Honda XR75 and JDM Vertical Motors
    Last Post: 06-23-2013, 12:59 PM
  2. "78 XR75 Head Swap
    By Dirttrack33 in forum Vintage Honda XR75 and JDM Vertical Motors
    Last Post: 11-29-2010, 07:04 AM
  3. ssr150- 155z motor swap,suspension swap
    By mxkid247 in forum Chinese/Import Minis - General Discussion
    Last Post: 11-05-2009, 09:56 PM
  4. XR75 front end swap?
    By zMan in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-16-2005, 03:22 PM
  5. XR50 motor swap....CT110 motor
    By blackXR5o in forum CRF50
    Last Post: 04-24-2005, 12:41 PM
