Dual Piston Brakes - Bolt up and go on Marzocchi Fork Legs! - Page 2
This is a discussion on Dual Piston Brakes - Bolt up and go on Marzocchi Fork Legs! within the Wholesale-Cycle forums, part of the PM Supporting Vendors category; Originally Posted by Johner@Pax Racing Best way to get the correct measurement is to use the back side of the calipers and measure inside to ...
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Like Tree2Likes
Thread: Dual Piston Brakes - Bolt up and go on Marzocchi Fork Legs!
  1. #16
    shoehorse33's Avatar
    Jan 2007
    Phoenix, AZ
    Quote Originally Posted by Johner@Pax Racing View Post
    Best way to get the correct measurement is to use the back side of the calipers and measure inside to inside of one hole then leave that measurement where it is and zero it out. From there measure from hole to hole all the way to the end. When you measure just the hole then zero it out and measure it end to end it's real acting as you measuring it from the middle of each hole. Hope it make since but what you sent will get them close enough to see I am sure.
    Got ya. Basically using the diameter of the hole to give you the dead center point.
    I should have thought of that earlier. Lol
    Red Baron Racing FMF Racing EVS-Sports Moto-Gate A-1 Autos Inc
  2. #17
    Johner@Pax Racing's Avatar
    Feb 2011
    CA, 93543
    Yup exactly. But the way you did it is close enough
  3. #18
    is ready for outdoors!
    www.wholesale-cycle.com's Avatar
    Aug 2012
    Akron, Ohio USA
    thanks for the help johner , have had no issues with these on any of the racebikes here at the shop!
    Hidden Content - We've got it in stock!
    The worlds largest source for Pit Bikes, Engines, Parts, and the maker of Piranha Pit Bikes.
    Hidden Content - Hidden Content - Hidden Content - 330-434-7777
    Hidden Content
    dualpipeklx's Avatar
    Feb 2008
    york, pa
    Would these work on 04 ktm 65 forks?
  6. #20
    Aug 2012
    Akron, Ohio USA
    Quote Originally Posted by dualpipeklx View Post
    have not tried them on the ktm65 , check the spacing which should be the same but rotor may be different
    Hidden Content
  7. #21
    is Reeg CRF50 build with 117cc
    stroker. Find my thread and
    subscribe!!
    dccycles's Avatar
    Nov 2012
    Wilmington,NC
    So you get the caliper, brake line and master cylinder with lever correct? I can use my 200mm formula rotor right?
    CRF50- Xtreme frame, take 88 kit, TB 20mm carb/cdi, BBR SP-5 fork kit, ada skidplate, 50 stunt peg bracket/f-r stunt pegs/12 bar/f-r brake arms/gas cap,1 industries graphics/plastics, sano billet throttle, big gun exhaust, TB HD clutch/BBR springs, TB oil pump, ada racing dress up kit, BBR bars, pro wheels with fast 50s hubs/BBR HD spokes.
  8. #22
    Aug 2012
    Akron, Ohio USA
    Quote Originally Posted by dccycles View Post
    correct!
    Hidden Content
  9. #23
    Jan 2007
    Phoenix, AZ
    Noticed on Pax Racing that they carry a Formula 200mm Adapter. Would this adapter allow the dual piston caliper to work with my Red Baron forks?
  10. #24
    Aug 2012
    Akron, Ohio USA
    Quote Originally Posted by shoehorse33 View Post
    You may have to ask johner about the adapter, he would know more about what it would work on. I know these will bolt up to the marzocchi but in your case your spacing looks a bit different as well as the angle.
    Hidden Content
  11. #25
    Leone627's Avatar
    Jul 2013
    Sorry to bring up such an old thread but do you think this would be a hassle with a joker tornado throttle? Since it is kind of spacious. Thanks
  12. #26
    Aug 2012
    Akron, Ohio USA
    Quote Originally Posted by Leone627 View Post
    nope it should still work fine
    Hidden Content
  13. #27
    puna_status's Avatar
    Apr 2016
    do you guy still have these in stock?
  14. #28
    is Took Portland's job. I may be
    getting demoted again...
    Jarret53's Avatar
    Aug 2009
    Massachusetts
    Quote Originally Posted by puna_status View Post
    I can add it to may cart so I would say yes
  1. Marzocchi fork legs
    By minirider54 in forum Feelers and What is my bike/parts worth?
    Last Post: 02-09-2009, 05:56 AM
  2. marzocchi fork legs
    By MATT 566 in forum KLX110/Midsize Parts for Sale
    Last Post: 01-21-2009, 06:14 PM
  3. KLX110 Marzocchi fork legs New Style Dual Comp and Reb
    By siktendenciesracing in forum KLX110/Midsize Parts for Sale
    Last Post: 01-09-2009, 11:07 AM
  4. Dual Piston Brake Setup For Marzocchi 35 Shivers
    By p3racer in forum CRF50/CRF70 Parts For Sale
    Last Post: 06-04-2007, 09:21 PM
  5. Wanted: Graphics, fork legs, disk brakes....
    By quadracer04 in forum CRF50/CRF70 Parts For Sale
    Last Post: 01-15-2006, 03:57 AM
2014 klx110l marzocchi fork
bbr 220mm brake
brake setups on marzocchi forks
crf50 220mm rotor
ktm 50 front forks mod
marzocchi brake set ups
marzocchi forks 200mm front brake
marzocchi hub
marzocchi klx110 forks
old style marzocchi forks klx110
what front brake do you use on klx 110 marzocchi forks
wholesale cycle marzocchi brake
