Dual Piston Brakes - Bolt up and go on Marzocchi Fork Legs!
This is a discussion on Dual Piston Brakes - Bolt up and go on Marzocchi Fork Legs! within the Wholesale-Cycle forums, part of the PM Supporting Vendors category; Have them back in stock and ready to ship , direct bolt on and ride to the marzocchi fork legs! Dont worry about the little ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Like Tree2Likes
Thread: Dual Piston Brakes - Bolt up and go on Marzocchi Fork Legs!
    is ready for outdoors!
    www.wholesale-cycle.com's Avatar
    Aug 2012
    Akron, Ohio USA
    Have them back in stock and ready to ship , direct bolt on and ride to the marzocchi fork legs! Dont worry about the little formula brakes or trouble bleeding, upgrade to the dual piston brakes with no issues! We are running a 220mm rotor with this setup.
    Hidden Content - We've got it in stock!
    The worlds largest source for Pit Bikes, Engines, Parts, and the maker of Piranha Pit Bikes.
    Hidden Content - Hidden Content - Hidden Content - 330-434-7777
    Hidden Content
    Johner@Pax Racing's Avatar
    Feb 2011
    CA, 93543
    I used thoses brake for along time and they work very well.
    KlxRacer#2 likes this.
    Bean573's Avatar
    Jul 2011
    Australia
    Is there a 220mm disk that will fit a marzocchi hub for this setup?
    shoehorse33's Avatar
    Jan 2007
    Phoenix, AZ
    Will this setup work for anything other than Zokes?
    Say a Red Baron front end possibly?
    Red Baron Racing FMF Racing EVS-Sports Moto-Gate A-1 Autos Inc
    Aug 2012
    Akron, Ohio USA
    Quote Originally Posted by Bean573 View Post
    We have front rotors but they are not the same bolt pattern as the marzocchi wheel , u may have to run our wheel or try to get ahold of a galfer rotor.
    I will have Justin bring home a set and play around with his marzocchi wheel and see what he can find out.
    *Bean what mm rotor comes stock on that formula rotor ?
    Hidden Content
    Aug 2012
    Akron, Ohio USA
    Quote Originally Posted by shoehorse33 View Post
    We havent done any testing with the red baron front end , just the fastace and the marzocchis we run. If you can give me some measurements i can let you know
    Hidden Content
    Jan 2007
    Phoenix, AZ
    Quote Originally Posted by www.wholesale-cycle.com View Post
    What measurements do you need and I will get them for you?
    Thanks.
    Aug 2012
    Akron, Ohio USA
    Let me know from bolt hole to bolt hole on the fork leg where the brake bolts on
    Hidden Content
  10. #9
    Jan 2007
    Phoenix, AZ
    Ok will do.
  11. #10
    is living the american dream!
    KlxRacer#2's Avatar
    May 2010
    we scrub harder in Ohio!
    here are the brakes being used on johner's old bigminis bike with a formula rotor.
  12. #11
    Feb 2011
    CA, 93543
    Quote Originally Posted by KlxRacer#2 View Post
    I used them with formula 200mm rotor but I have also use with the Hayes 180mm rotor because it is 5 mm thick compared to the formula 200mm that is only 2.5mm thick. Works well with either rotor. If your able to find a BBR waver rotor then it will even be better because it is 5mm thick and 200mm rotor size. Either way brakes are good and ASV makes a lever for it too
  13. #12
    Banned
    starfish895's Avatar
    Nov 2012
    la mirada california
    Price?
  14. #13
    is Took Portland's job. I may be
    getting demoted again...
    Jarret53's Avatar
    Aug 2009
    Massachusetts
    Just click on the first picture and it brings you right to the site with the part
    front brake assy
    Complete Brake Systems
    (Item no: 2075)
    Our Price: $66.89
  15. #14
    Jan 2007
    Phoenix, AZ
    Hope I measured correctly. Let me know if I did this wrong.
    On the fork leg the holes were 15.0mm apart.
    Measured the caliper mount too just in case it might help.
  16. #15
    Feb 2011
    CA, 93543
    <img src="http://planetminis.com/forums/attachment.php?attachmentid=109908"/>
    <img src="http://planetminis.com/forums/attachment.php?attachmentid=109909"/>
    Best way to get the correct measurement is to use the back side of the calipers and measure inside to inside of one hole then leave that measurement where it is and zero it out. From there measure from hole to hole all the way to the end. When you measure just the hole then zero it out and measure it end to end it's real acting as you measuring it from the middle of each hole. Hope it make since but what you sent will get them close enough to see I am sure.
  1. Marzocchi fork legs
    By minirider54 in forum Feelers and What is my bike/parts worth?
    Last Post: 02-09-2009, 05:56 AM
  2. marzocchi fork legs
    By MATT 566 in forum KLX110/Midsize Parts for Sale
    Last Post: 01-21-2009, 06:14 PM
  3. KLX110 Marzocchi fork legs New Style Dual Comp and Reb
    By siktendenciesracing in forum KLX110/Midsize Parts for Sale
    Last Post: 01-09-2009, 11:07 AM
  4. Dual Piston Brake Setup For Marzocchi 35 Shivers
    By p3racer in forum CRF50/CRF70 Parts For Sale
    Last Post: 06-04-2007, 09:21 PM
  5. Wanted: Graphics, fork legs, disk brakes....
    By quadracer04 in forum CRF50/CRF70 Parts For Sale
    Last Post: 01-15-2006, 03:57 AM
2014 klx110l marzocchi fork
bbr 220mm brake
brake setups on marzocchi forks
crf50 220mm rotor
ktm 50 front forks mod
marzocchi brake set ups
marzocchi forks 200mm front brake
marzocchi hub
marzocchi klx110 forks
old style marzocchi forks klx110
what front brake do you use on klx 110 marzocchi forks
wholesale cycle marzocchi brake
