12" Front Rim
12" Front Rim
This is a discussion on 12" Front Rim within the Yamaha TTR50 forums, part of the General Talk category; Every time i post i only get 1 or 2 replies haha. This forum needs a little more life. So i was thinking with stock ...
Results 1 to 8 of 8
Thread: 12" Front Rim
    cody344's Avatar
    Nov 2011
    Chester, NH
    Every time i post i only get 1 or 2 replies haha. This forum needs a little more life. So i was thinking with stock forks with heavy duty springs i was going to run a 12" FRONT wheel and a aftermarket rear shock (like a float or ishock). My thought were better handling and more ground clearance. Has anyone dont this with stock forks and stockk swingarm (still running 10" rear).
    lippsn610's Avatar
    Oct 2010
    Osage Beach, MO
    i dont believe it would look right. that stock swingarm will look really disproportional compared to the front end. also im sure itll sit really front end high
    millersmini's Avatar
    Oct 2009
    Ohiopyle, PA
    will the 12" front tire clear the head of the motor with stock forks? But I agree I don't think the bike would sit correctly.
    cody344's Avatar
    Nov 2011
    Chester, NH
    well it will raise the front 1" because that extra 2" diameter in the wheel is slit on each side, so that in conjunction with a slightly longer shock i thought might work and make it sit correctly. The clearances are ok though. Perhaps i will buy a cheap knockoff rim on ebay to try it first before i buy a $150 rim and spokes
    is getting old.!!!!
    BUZZ 50s BROTHERHOOD's Avatar
    Oct 2006
    south wales..uk
    run ttr 90 forks with ttr 90 front wheel plus 5 swing arm on longer shock.....or you can do it like my old ttr 50...
    JonHammermeister's Avatar
    Sep 2011
    Yakima, WA
    I to am looking to add the 12" front wheel - however this is not a pit bike. My son races Hare Scrambles and needs a bigger front tire/wheel combo to roll over obstacles easier. Any help here...
    is currently licking windows
    doopsx3's Avatar
    Aug 2008
    Yucca Valley
    I think that PW80 forks will work as well.....I researched this once and I remember (I think) that the PW80 could be used/modifed to work....however in the interim I got a sweet deal on some TTR50 SP-5s so now I have the set of PW80 forks that I am not going to use so I am not going to put the theory of PW80 forks to work....bummer
    GYTR804's Avatar
    May 2012
    RICHMOND,VA
    I have TTR-50 with 12" front and rear tires. I love the 12" over 10". I order mine at BBR
12 front wheel for ttr50
12 in front on ttr 50
12 ttr50 front wheel
are ttr 50 and ttr 90 same front tire
how to take off the front rim from a yamaha ttr 90
pw80 12 front rim
pw80 rims
ttr 50 10 wheels to 12
ttr 50 rear shock
ttr 90 pit bike
yamaha ttr 50 forks and 12 in rim
yamaha ttr50
