Hey everybody got a new ttr project i will be starting. Stay tuned for more details
This is a discussion on Project Superpro within the Yamaha TTR50 forums, part of the General Talk category; Hey everybody got a new ttr project i will be starting. Stay tuned for more details...
Frame check, swingarm check, big bike shock check, seat check,gastank check. Just need plastics and my graphics and the conversion is on
Sweet, interested to see how this turns out.
Update. Project super pro has become project perimeter. Stay tooned
Polished sub[ frame moving forwardATTACH=CONFIG]88727[/ATTACH]
How? What is your plan? A crf base motor and bbr style crf tank? Thats not a ttr50 then.
How are you goin to put a ttr tank and engine on a bbr perimeter frame.
the superpro frame is easy with crf base engine. ive done it.
1. drill hole horizontally across the tank mount ( mount with two washers as spacers with single bolt and nut.)
2. put 4 washers or two spacers to fill the gap where seat bolts to subframe (hone out holes a little)
3. build aluminum (CNC) or steel bracket to mount rear of tank. (ull basically have a retangle with a bolt hole at each end and one in center ) use stock bolt for center and two short bolts with nuts on ends)
can be done in 10mins once u have made rear tank bracket
Im curiuos to ear your plan and ideas
I will be running cfr50 plastics and primmy gastank I like the look better. What else did you do to your superpro. I feel.if it powered by yamaha then its a yamaha
Yea i know that is the bad part about the aluminum frame, the primmy had a couple of cracks on it so to fix them i have to re heat treat it. Larry said he would have all welding done first then have it treated so just gonna do the new motor mounts and and send it to bbr and they will do the rest.
Wheres the update...haha cant wait to see her man
The repairs are done just need to pull my engine so I can get my engine mounts done should be done by end of week
if i were you i would do ttr plastics with a crf50 motor.. you have WAY BIGGER selection of parts that are easier to get ahold of and cheaper then the ttr50 motor.. and if you ever go to part it no one will want to but it becuase no one is going to put a ttr motor i a 50 frame. the plastics would be kool because no one has it but the motor is kinda a dumb idea in my opinion not only are you wasting money your screwed in the long run.
Props for venturing out a bit with your build. Don't see a lot of built TTR 50s around here!
Well when the Ttr50 engine is 118 kitaco with race head it pretty much rips. My whole thing is this is my bike and unless I'm living under a bridge its not for sale. Thanks for the feedback besides I'm sure 10 years ago somebody was doing this to a crf50. All engine parts are available so I have no worries
Looks like a wild ride man, bet you cant wait to ride it![]()
Lookin killer Logan, you get your bars yet? I STILL havent even looked at the frame and plastics yet, box got stuffed in the garage out of the way while I was selling one of my harleys and a ton of parts I was tripping over every time I want to get near my dirtbikes!
Matt
