Need help on the ttr 50
This is a discussion on Need help on the ttr 50 within the Yamaha TTR50 forums, part of the General Talk category; Hello i have a question on my daughters ttr 50 to start off my 10yr old son and his buddy where beating on it and ...
Hello i have a question on my daughters ttr 50 to start off my 10yr old son and his buddy where beating on it and the said the chain fell off so i put the chain back on and started up the bike and i made a bad sound in the trans and it wont go into gear so i was looking around and the front sprocket has some play in it just wondering if this has happened to anyone else because this thing only has about 15hrs on it and also wondering if the trans gear is bad do u have to split the cases? thanks keith
04-15-2012 11:39 AM
Yes you have to split the case I've had my bike for 6 years and no issues with transmission. Try adjusting clutch first might free something up
- You may not post replies
- You may not edit your posts
Forum Rules
2012 ttr50 electric start problem
how many gears does a yahama ttr 50 have
how many gears on ttr50
how to set the governor on yamaha ttr 50
how to tighten a yamaha 50 chain
ttr 50 clutch adjustment
ttr 50 electric start
ttr 50 electric start problem
ttr 50 electric starting problems buzzing
where is governor screw on ttr 50
where is the clutch adjustment for a ttr 50 yamaha
yamaha ttr 50 bad transmission
