TTR50 Transmission problems(help)
This is a discussion on TTR50 Transmission problems(help) within the Yamaha TTR50 forums, part of the General Talk category; I have a 08 ttr50 electric start. I am having transmission problems. Hoping somebody could point me in the right direction. When I crank it ...
Results 1 to 3 of 3
    nickw23's Avatar
    Jul 2014
    I have a 08 ttr50 electric start. I am having transmission problems. Hoping somebody could point me in the right direction. When I crank it up it is making a knocking noise in neutral. When I shift into first it starts bucking and feels like it is slipping and then grabbing, but when I shift into 2nd and 3rd it runs and drives fine but is still making the knocking noise except not as loud. Its not terribly loud in neutral and 2nd and 3rd but in 1st it is louder. I pulled the flywheel cover off and the starter idler gear was messing teeth but I replaced it. Any help would be great. Thanks
    vidnoye's Avatar
    Jul 2015
    Hi,
    I know this is kind of an old post but did you get it fix?
    I have a TTR50 and is doing the same thing you described. I think my kid forced it too much and it started making a rattling sound, I took the cover off, found 3 or 4 teeth but I didn't see any gear missing teeth. I haven't restarted yet but I was wondering what did you find out? how much was it to fix?
    thanks
    Steven Kooli's Avatar
    Apr 2017
    I've got the same problem. My TTR50 2009 makes a knocking/clicking in 1st and 2nd gear and the sound pretty much disappears in 3rd. Split the case, pull everything apart and found nothing visibly wrong with the transmission. No teeth missing, put it back together and it started easy and runs well. I didn't remove the clutch and look under there, but couldn't see anything wrong visibly underneath the clutch, all teeth on all gears are still there. Does any one know what issue/problem I should be looking for? Or what is causing the knocking clicking sound???
  1. Transmission Problems. HELP!
    By pitbikeking18 in forum KLX110, DRZ110, TTR90
    Last Post: 11-05-2013, 02:45 PM
  2. Transmission problems
    By Pitviking in forum Chinese/Import Minis - General Discussion
    Last Post: 09-12-2009, 01:22 AM
  3. ttr50 Transmission noice
    By Erik Nup in forum Yamaha TTR50
    Last Post: 06-01-2009, 09:08 PM
  4. transmission and clutch problems
    By macworld in forum CRF50
    Last Post: 04-09-2006, 10:23 PM
  5. Transmission Problems
    By arlindsay1992 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 03-20-2006, 05:44 AM
2006 yamaha ttr50 transmission problems
rattling sound ttr50
transmission on a ttr50 making stripping noise
ttr50 clutch noise
ttr50 problems
ttr50 slipping
ttr50 transmission noise
yamaha ttr 50 2015 problems engaging trans
yamaha ttr 50 clicking noise
yamaha ttr 50 transmission problems
yamaha ttr50 gearbox fault
