2006 TTR 50 oil leaking from stator cover
This is a discussion on 2006 TTR 50 oil leaking from stator cover within the Yamaha TTR50 forums, part of the General Talk category; My 2006 TTR 50 is leaking oil from what I believe is the bottom front bolt area of the stator cover. I have cleaned everywhere ...
Results 1 to 1 of 1
    Twenty36_1's Avatar
    May 2009
    My 2006 TTR 50 is leaking oil from what I believe is the bottom front bolt area of the stator cover. I have cleaned everywhere around the cover, and a small amount is around the front bottom bolt, with no trail of oil coming from anywhere. I was looking on thumpertalk and searched in the TTR forum and saw mention of a "wet stator," (but it wasn't for the 50. just 125 and up from what I found) and that some oil in there is normal. Is this the case? If so I think I just need a new gasket, but I want to be sure it isn't a bigger problem before ordering the gasket.
  1. Help! Oil leaking from stator cover on 110 E-start (w/ bottom mounted starter)
    By scottro in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-08-2014, 05:20 PM
  2. crf50 stator cover and stator
    By TAR MX in forum Bikes and Parts Wanted - All Makes
    Last Post: 08-06-2013, 09:27 PM
  3. NEED klx 110 stator cover and stator/magneto ASAP
    By Petersen114 in forum Bikes and Parts Wanted - All Makes
    Last Post: 02-22-2013, 01:01 AM
  4. WTB: klx drz 110 stator and stator side cover!!
    By Rollie in forum Bikes and Parts Wanted - All Makes
    Last Post: 12-15-2010, 07:30 AM
  5. Cam cover leaking???
    By yernkie in forum CRF50
    Last Post: 05-16-2010, 01:11 PM
