Hand guards for Yamaha TTR 50
This is a discussion on Hand guards for Yamaha TTR 50 within the Yamaha TTR50 forums, part of the General Talk category; Hello guys , I just bought a TTR 50 for my little dude. Could please recommend a good hand guards that would fit Yamaha TTR ...
Results 1 to 3 of 3
    ziser77's Avatar
    Apr 2016
    Hello guys , I just bought a TTR 50 for my little dude. Could please recommend a good hand guards that would fit Yamaha TTR 50 ?
    Thank you
    is Lurking in the shadow's
    my67xr's Avatar
    Jan 2013
    South Australia
    With the TTR50 having 3/4" handlebar's you might need to make up some custom mount's as most are suited to 7/8" bar's.
    It could be as easy as clamping some rubber strap in between the mount and bar's to make up the difference
    Depending on what style hand guard's you get, some have a metal strap in them,
    one end clamp's to the bar's the other end goes out and around the lever and end's level with the end of the throttle tube, then you screw it into a rubber bung inside the bar end
    You need to cut the end off your grip's and throttle tube to use this type.
    The end cap's could be made with some solid rubber rod and screw some self tapper's into them.
    If you can get them cheap then you won't mind modding them to suit.
    There are lot's of different type's here-
    Shop BLUE dirt bike hand guards online Gallery - Buy BLUE dirt bike hand guards for unbeatable low prices on AliExpress.com
    blue hand guards | eBay
    I mounted some on my son's PW50, i had to make a mount for the inside bolt's to hold them to the bar's
    They worked well and he never hurt his hand's if he came off.
    I have since fitted some 7/8 bar's to the bike but haven't swapped the hand guard's over yet.
    ziser77's Avatar
    Apr 2016
    Thank you very much for your response , so basicly I can buy a regular 7/8 handguards and then modify them in order to fit TTR?
    Correct ?
  1. hand guards? yes or no
    By diggin dirt in forum KLX110, DRZ110, TTR90
    Last Post: 01-24-2011, 03:46 PM
  2. Hand Guards
    By Fall_Guy in forum CRF50
    Last Post: 07-31-2008, 03:40 PM
  3. hand guards?
    By Mx__501 in forum KLX110, DRZ110, TTR90
    Last Post: 07-20-2008, 10:52 PM
  4. What hand guards to run?
    By robbieyukon in forum KLX110, DRZ110, TTR90
    Last Post: 02-12-2008, 02:52 PM
  5. hand guards for an 80
    By Zachmotox179 in forum CRF50/CRF70 Parts For Sale
    Last Post: 03-07-2007, 02:18 PM
