Internal engine image of Guide Shift Comp. and shift arm or clutch?
This is a discussion on Internal engine image of Guide Shift Comp. and shift arm or clutch? within the Yamaha TTR50 forums, part of the General Talk category; Hi all, Of all the pics out there on the web, I cannot seem to find one of how the internal shift arm and guide ...
Results 1 to 3 of 3
    fghdrock's Avatar
    Nov 2016
    Hi all,
    Of all the pics out there on the web, I cannot seem to find one of how the internal shift arm and guide shift are seated on top of the clutch. I am in the process of replacing the clutch and want to confirm if the shifter sits in the center of the fork or not. Or maybe it doesn't matter. Unfortunately I was troubleshooting something else when I popped the cover off and now I do not remember how it goes.
    Does anyone have a simple picture of the right side of the engine with the cover off? I found the diagrams and that looks like it would sit in the middle, but an actual pic would be a great reference.
    Thanks
    fghdrock's Avatar
    Nov 2016
    By the way, this is for a 2009 ttr50.
    fghdrock's Avatar
    Nov 2016
    figured it out
  1. shift drum? shift arm problem?
    By mattmako in forum KLX110, DRZ110, TTR90
    Last Post: 04-07-2015, 10:37 PM
  2. KLX/DRZ 110 shift shaft 05+ or quick shift and lever
    By braaap11889 in forum Bikes and Parts Wanted - All Makes
    Last Post: 11-07-2012, 09:06 PM
  3. Replies: 8
    Last Post: 03-18-2012, 01:19 PM
  4. Replies: 15
    Last Post: 12-05-2007, 12:43 AM
  5. KLX 110 Broken shift shaft/ bent shift fork??
    By wildchildc1 in forum KLX110, DRZ110, TTR90
    Last Post: 05-17-2005, 11:02 PM
internal engine images of yamaha
